Autonomous mode
Where are the variables that are used in autonomous code declared?
Just make sure you declare them outside of the “while(autonomous_mode)” loop and everything should be fine.
i need help on how to program our controls using labview 8.2
i need help programing our controls using labview 8.2
You might want to delete your double-post because people will see it and negative-rep you…
You don’t straight-up code with LabView. You either use easyC or MPLAB to code the controls. I don’t know LabView well enough to instruct you on how to use it, but there are plenty of threads on how to program around here.
JBot
