Autonomous modes?
Looking for an autonomous code to use as a test. please reply ASAP
IF auton=0 then 100 'jump if not auton mode
Ldrive = 254
Rdrive = 0 'pre-emptive victory spin
100: 'continue with rest of code
ok, Im joking around - most peoples auton code from last year is specific to there robot - what do you want your bot to do in auton mode?
  • FUNCTION NAME: Sample_Auto_1
  • PURPOSE: Primitive form of autonomous mode program
  •            This overrides the PWM joystick inputs
  • CALLED FROM: user_routines.c, Default_Routine
  • ARGUMENTS: none
  • RETURNS: void
    void Sample_Auto_1(void)
    static unsigned int counter=0;
/* Sample primitive autonomous mode
  • This uses a counter of the number of slow loops as a measurement for how long
  • to execute any of the PWM overrides below.
  • Note: A timer can also be used in place of “counter”
    if (counter<100){
    counter++;
    PWM_in1 = 200;
    PWM_in2 = 200;
    else if(counter< 150){
    counter++;
    PWM_in1 = 127;
    PWM_in2 = 10;
    else if(counter< 500){
    counter++;
    PWM_in1 = 127;
    PWM_in2 = 127;
    else if(counter<700){
    counter++;
    PWM_in1=254;
    PWM_in2=1;
    else if(counter<900){
    counter++;
    PWM_in1=1;
    PWM_in2=127;
    else /* Make sure it always stops at the end */
    PWM_in1 = 127;
    PWM_in2 = 127;
} /* End Sample_Auto_1 */
thanx man
if you want some more interesting code, our edu bot does the hokey-pokey in the autonomous mode… if you want the code, i can get it from our programmer
put your right foot in, pull your right foot out, put your right foot in and shake it all about… :smiley:
