Hi! I’m working on some autonomous code for my robot. The code is to drive forward. In the code, it should be under the function driveForward(). Anyways, what I would like to do is to be able to make it drive forward at a certain speed for a certain amount of time. I have the speed down, and it’s driving. I just need to know how to do the timed stuff. Sorry if it’s a pretty basic question. I just started programming autonomous and I have never done this before.
Here is the code that includes driveForward():
package org.usfirst.frc.team4501.robot.subsystems;
import org.usfirst.frc.team4501.robot.RobotMap;
import org.usfirst.frc.team4501.robot.commands.DriveArcade;
import edu.wpi.first.wpilibj.AnalogGyro;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import edu.wpi.first.wpilibj.DoubleSolenoid.Value;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.command.Subsystem;
public class DriveTrain extends Subsystem {
public enum ShifterState{
SF_HIGH, SF_LOW;
RobotDrive drive;
Talon rightTalon;
Talon leftTalon;
DoubleSolenoid shifter;
ShifterState state;
AnalogGyro gyro;
Encoder L_Encoder;
Encoder R_Encoder;
// Put methods for controlling this subsystem
// here. Call these from Commands.
public DriveTrain(){
this.leftTalon = new Talon(RobotMap.LEFTMOTOR);
this.rightTalon = new Talon(RobotMap.RIGHTMOTOR);
this.drive = new RobotDrive(leftTalon, rightTalon);
this.shifter = new DoubleSolenoid(RobotMap.SOLENOID_HIGHGEAR, RobotMap.SOLENOID_LOWGEAR);
this.gyro = new AnalogGyro(RobotMap.GYRO);
this.L_Encoder = new Encoder(RobotMap.Encoders.L_A, RobotMap.Encoders.L_B);
this.R_Encoder = new Encoder(RobotMap.Encoders.R_A, RobotMap.Encoders.R_B);
public void initDefaultCommand(){
setDefaultCommand(new DriveArcade());
public void arcadeDrive(double forward, double rotate){
drive.arcadeDrive(forward, rotate);
public void initGyro(double gSensitivity){
gyro.initGyro();
gyro.reset();
gyro.setSensitivity(gSensitivity); //volts Per Degree Per Second
public void sensorReset(){
gyro.reset();
L_Encoder.reset();
R_Encoder.reset();
public void getSensors(){
long gyroAngle = Math.round(gyro.getAngle());
SmartDashboard.putNumber("Gyro Angle", gyroAngle);
SmartDashboard.getNumber("Gyro Rate", gyro.getRate());
SmartDashboard.putNumber("Right Encoder Distance", this.R_Encoder.getDistance());
SmartDashboard.putNumber("Left Encoder Distance", this.L_Encoder.getDistance());
SmartDashboard.putNumber("Right Encoder Rate", this.R_Encoder.getRate());
SmartDashboard.putNumber("Left Encoder Rate", this.L_Encoder.getRate());
public void highGear() {
shifter.set(Value.kReverse);
state = ShifterState.SF_HIGH;
public void lowGear() {
shifter.set(Value.kForward);
state = ShifterState.SF_LOW;
public void set(ShifterState state) {
switch (state) {
case SF_HIGH:
this.highGear();
break;
case SF_LOW:
this.lowGear();
break;
public ShifterState getState() {
return state;
public void forwardMove(double x, double y){
this.leftTalon.set(x);
this.rightTalon.set(y);
Here is the code which includes the autonomous section:
package org.usfirst.frc.team4501.robot;
import org.usfirst.frc.team4501.robot.commands.DriveIdle;
import org.usfirst.frc.team4501.robot.subsystems.DriveTrain;
import edu.wpi.first.wpilibj.command.Command;
import edu.wpi.first.wpilibj.command.Scheduler;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the IterativeRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
public static OI oi;
Command autonomousCommand;
DriveTrain drive;
// Subsystems
public static final DriveTrain driveTrain = new DriveTrain();
public void robotInit() {
oi = new OI();
driveTrain.initGyro(.0069);
public void disabledPeriodic() {
Scheduler.getInstance().run();
driveTrain.sensorReset();
// schedule the autonomous command (example)
if (autonomousCommand != null) {
autonomousCommand.start();
* This function is called periodically during autonomous
driveTrain.forwardMove(0.05, 0.05);
public void teleopInit() {
// This makes sure that the autonomous stops running when
// teleop starts running. If you want the autonomous to
// continue until interrupted by another command, remove
// this line or comment it out.
if (autonomousCommand != null) autonomousCommand.cancel();
Scheduler.getInstance().add(new DriveArcade());
* This function is called when the disabled button is hit.
* You can use it to reset subsystems before shutting down.
public void disabledInit(){
Scheduler.getInstance().add(new DriveIdle());
* This function is called periodically during operator control
driveTrain.getSensors();
* This function is called periodically during test mode
public void testPeriodic() {
LiveWindow.run();
Thanks!:]
