Axis 206 camera
How do you program the axis 206 camera motors. I believe it has servo motors to move it but how do I program it. If someone could post a basic code for it that would make it work, I would greatly appreciate it.
see what I have posted for help with programming I think I posted after you did, it is titled “help with servo programming”, it might help you.
ok I looked at what you posted I will give it a try.
The default code from 2008 did a servo mounted camera, and because of that, there is a Two Color Servo Camera Example that ships with LV. You can open it form the Help menu or the getting started. The code is a bit complex because it was trying to quickly process and follow the green/pink cylinder, but you can see how the bottom loop moves the camera around.
Greg McKaskle
