Hello, everyone. We’re experiencing an issue that whenever the camera is successfully connected to the robot (either to the bridge or the cRIO), it seems to be causing lag, where the controls are jumpy and unpredictable. However, when we unplug the camera from its port, the robot immediately begins behaving as expected. Any suggestions? Thanks.
A few details that may make a difference:
-We are using the Axis Camera 206.
-We have an 8-slot cRIO.
-We have implemented the Rectangular Target Processing VI into our Vision Processing.
-The program works just fine when the camera is not plugged in.
-I was not able to change the FPS in time before leaving the shop, in case that has anything to do with it.
-I have already tried putting the camera in the lowest possible resolution.
