Axis Camera Connection Issues
We have run the camera setup, set the FRC account name and password to FRC. We set the root password to admin. When we connect to the camera IP when it’s plugged in it shows on the live video feed. When we unplug the camera and plug it into the 2nd ethernet slot, though, the dashboard shows no video and gives us an error. Everything else about the robot works, programs run fine and everything. Here is the error:
ERROR <Code> -44003 occurred at WPI_CameraIssue HTTP Request with Authentication.vi>>WPI_CameraIssue Get.vi>>WPI_CameraGet Image Appearance Property.vi>>WPI_CameraGet Enum Sensor Property.vi>>WPI_CameraGet Exposure.vi>>WPI_Camera Registry.vi>>WPI_CameraOpen.vi>>Begin.vi>>Robot Main.vi
<time>23:24:47 02/09/2012
FRC: Operation failed due to a communication failure with the camera.
We’re using the crossover ethernet cable to plug it in, the lights on the crio ethernet slot light up and everything. I just have no idea what else could be going wrong. Any help is appreciated.
The camera defaults to being plugged directly into the DLink, not the cRIO.
Both the cRIO and Dashboard expect to find it there.
