Axis Camera setup in Labview
Ever since the NI Labview update v14, running camera feed has been ridiculous. We want to use an Axis Camera, but since the “Vision Processing.vi” was disabled in the Robot Main, we don’t know where to start.
TLDR: How can you setup an Axis Camera in Labview? How do you connect an Axis Camera to the RoboRio?
I’m not sure what you mean by the vi being disabled. Could you explain more? We are using axis cameras and have not had any issues.
There are screensteps that walk you through setting up the camera, and a program supplied that will do the work for you. Then you click the vision enabled boolean on the robot main vi to turn it on.
https://wpilib.screenstepslive.com/s/4485/m/24194/l/144985-configuring-an-axis-camera
My response will change greatly depending on whether you want to process the image for targeting or just steam it to the dashboard. Please specify, as I can provide assistance for either case.
