Axises
I know what Axis 1 and 2 are. But I dont really know what axis 3 (throttle), 4 5 and 6 are. If I control a servo motor on axis 4 I cant really see a change in the behaviour of servo even if I make joysticks go every direction.
Can someone help me?
Thanks in advance!!!
The Joysticks that came in the Kit of Parts only report values on Axis 1, 2, and 3. Axis 1 and 2 are the X and Y of the joystick. Axis 3 is the throttle “dial” on the back of the joystick base.
Axis 4, 5, and 6 are not used on the joysticks in the Kit of Parts.
The othe axis are for diffrent usb controllers
For example if you find a fight joystick the rotation will be axis four
or if you use a controller with more than one stick like the logitech the axis will be left x=1 left y=2 right x=3 right x=4
Thank you, now I can control the servo
