Axon install on Macbook
Does anyone know how to get Axon installed on a Macbook? I have Docker installed, downloaded the dmg package and moved it to the Applications folder. But that’s not going to build or install a Docker image. There must be one other step that I’m missing. Does anyone know the name of the image? There are no instructions in the Axon README or in the FRC documentation. Thank you.
It’s been several months since I did this, but I don’t recall any missing or hidden steps. I don’t remember having to build a Docker image. I believe it is included in the installation.
If you installed Axon and Docker, I think you just run the Axon launcher and then point your browser at the service it creates.
Thanks for the reply. When I run the Axon launcher nothing happens. I would expect it to build the docker image and run it, but after half an hour there’s no image and the launcher is still running. Anyway, I just cloned the Axon repository so I’ll dive into the code and figure out why it’s not working. Thanks again.
Do u fix this problem? I also have the same situation. thank you
