Hello,
I am wondering if there is a relatively easy way to run Axon on an external drive. I used up the extra 100gigs on my laptop yesterday. I looked to see if there were a quick setting in Docker, but I could not find one.
I would probably use an SSD in a USB 3.0 enclosure. I am running WIndows 10.
I’m not particularly familiar with axon, but if it’s running in docker, then it should be as simple as changing the volume mount path to use the external drive. If this is on windows, you’ll also need to enable access to that drive in the docker desktop settings.
