Ball balance
Testing with the FRC foam balls, they appear to be imbalanced in terms of density. Will this be corrected for the competition or will we just have to compensate for the inaccuracy of the balls we are testing with?
The density is random. No two balls will be exactly alike.
Al- we’ve found the density of new balls to be extremely consistent.
If you have a ball you find particularly squishy, I’d bet money that it has holes poked in the side of it somewhere (from just tossing around, minor abrasion).
We have found that once the balls are punctured, their characteristics change dramatically.
-Brando
This is very disconcerting. I’ll have to notify my team.
I wonder if this was intentional or not?
It will not be “corrected” in my opinion, you would be wise to design flexibly.
Do you have the weight for a handful of the balls measured accurately at this point? Also, are they very accurately 7"?
Thanks!
-Mike
At least one of the three balls from our KOP has a bump on one side. These are simply (read ‘cheap’) foam and prudence would suggest that no two are alike.
We noticed the same and gave one a “floatation test” in a sink. One side always came to the top. These are cheap balls and vary considerably in balance.
So how does this compare to the balance of density of poof balls?
We live in an imperfect world.
We found a density difference in the balls which is part of their manufacturing. We found that the side with the injection gate is always heavier than the side without the gate. I believe it is an inherent part of the manufacturing process as the material is being injected into the mold. Once the mold has been filled the material starts to setup and the extra material used to assure a full cavity collects at the gate site causing the increased density.
This is nothing new. Remember “purple side down” in 2006?
It’s all part of the game challenge. Design accordingly.
