Ball Hogs
Usually each years game leaves enough objectives on the field to keep each member of an alliance busy.
ie.
07 = plenty of ringers
06 = plenty of poof balls
05 = plenty of tetras
04 = plenty of big and smal balls
03 - lots of bins
etc.
This year, 3 bots and 2 balls
Obviously if you want to win you need to handle the balls. So now when it comes to determining who on your alliance gets to do the bulk of the handling. How well do you think teams will stick to the plan? the term, ball hog comes to mind. I can see a pretty big problem in that, if I think my bot should have more access to our alliances balls than say, 1 or both of my alliance partners, how do we make that happen? To ask an alliance partner to minimize their interaction with the ball, so that we have more access to them, will/can be offensive. But if you’re coming up on a ball and your alliance partner is attempting to handle it, at a pace much less capable than yours, what do you do? Take it from them? or pass it in the name of GP and go for the 2 pt lap?
Yes there are strategies that employ the uses of each members capabilities, but many times, teams are determined to use a feature on their bot, regardless of its capability. We all need to work together, but I think this year more than ever, it will mean a win or loss if we don’t put faith in each other.
BTW - I don’t mean to say this is 179’s MO. This will be a fast paced game with quick decision making happening. I think it’s the knee jerk reactions that will break down alliance functionality. Like, do I bump the ball across now or pass it so team x can come up behind me and hurdle it?
I agree. Negotiating ball-handling with your alliance will be critical this year. With only two balls for three robots - and the possibility that your opponents may try to play keep-away with your ball, too - there will certainly be some heated discussion between alliance members.
It reminds me a bit of the situation in 2001, where there was only one bridge to balance for four teams. Most teams had some kind of bridge-balancing capability, and every team always wants to show off what they can do. Unless one team had a clear advantage (for example, Beatty), everyone would have to negotiate who got to be the one to balance the bridge. Teams who had a coach with a strong personality often had the advantage, because they would present the strongest argument for their team to be the one to balance.
I have a feeling that strategy discussions this year will sort out the same way. Coaches and drivers will have to make their case to their alliance why they need the ball, or come up with a strategy to share it during the match. Effectively sharing the two balls to maximize scoring will likely be the best way to do it, and those that can pull it off will have an advantage, I think.
If the plan involves one bot playing defense/herding the opponent’s trackballs, that leaves 1 ball per alliance bot. It’s an unheralded job, but sometimes, someone just has to do it.
I could see the ball hog concept being more of a problem when you get 3 capable offensive robots together, especially when the teams are used to being the “point man”, the center of attention. Who will swallow their pride and relegate themselves to more of a support/defensive role? Or how will they concoct a devious strategy where 2 robots manipulate one of the trackballs in glorious coordination and the other bot is free to use the 2nd trackball at will?
I view the best gameplay arrangement to be like football played with two balls - the quarterback and receiver bots work in tandem playing pitch and catch with one trackball, while the “running back” bot is free to use the other trackball as he pleases. But watch out, because if you fumble or throw an incomplete pass, the defense will be there to recover and slow down your offense.
It will be interesting to see how this game and this season plays out, no doubt!
It’s almost as if the GDC planned it this way…
I forsee that there will often be matches where you will have 2 ball handlers and a moving chicane.
Almost like Roller derby for robots isn’t it?
But yeah it seems that people who usually are the famed center of the alliance are going to have to cooperate. And when the rules say you can herd your enemy’s track ball you’re bound to get some possible stalemates between the alliances. After all if your trackballs are captured and the opponent’s balls are yours the only way to score is to go fast and try to score points by racing each other. And if they have slow robots then you pretty much have the problem with “gently bumping” to the other balls. Or as long as the opposition has a “rabbit” and the other robots just pin the balls against the arena you’re going to be in a lot of trouble if you aren’t fast.
We’ve been discussing a strategy we’ve dubbed “Dancing with 1114” that was inspired by the Q&A they submitted concerning hurdling. The description contained in their question reveals a “devious strategy” or more accurately, an ingenious strategy whereby three capable machines share the two trackballs. Cooperating in the process of hurdling such that neither ball ever touches the floor. Oh, by the way, both balls are on the overpass at the end. I imagine that the GDC envisioned just such a game play. It should be fun to watch. Imagine if six robots were doing the dance!! That would rival the six ringer auton at IRI:yikes:
huh? link?
Edit, found it, but I don’t get it? how can beta touch the ball without crossing the plane?
just to throw in my two cents -
When it comes to picking the teams for the elimination matches, teams will be looking for two good hurdlers and one fast scorer/defensive bot (at least, this is the most likely desired arrangement). Last year, our robot had the capability to pick up rings and place them on the rack. During the beginning part of the qualification matches, we realized that our robot wasn’t doing this as effectively as other robots, and we switched our strategy to become a very good defensive bot. The same situation should apply here - If we end up not being one of the faster hurdlers, then we’ll switch our own personal strategy to appeal to the other portions of the game play.
The whole point of the competition isn’t to be able to do just one thing - hurdling. It’s being able to distinguish your robot in some way that makes it a unique and valuable part of an alliance. If thats through hurdling, then great. If it’s through keep away, then great. It it’s through driving twice as fast as everyone else and expertly avoiding traffic jams, then great. All of these strategies are highly useful for a team to have and to show during the qualification matches.
I would encourage everyone to avoid trying to show off one particular aspect of their robot and instead look to whats best for their alliance. I know at our competitions, i’ll be encouraging our drivers and strategists to do whats best for our alliance, and i’ll be doing the same for the teams we work with.
Oh, and we plan to come prepared with information like average laptime and average hurdle time to help cement our position :slight_smile:
Our team thought of hurdling early on in the design process and nixed the idea because of this potential problem (three alliance partners competing for two balls). So we decided to design a robot to go for 24 points in hybird (one part of which is knocking down our alliances balls from the overpass) and then make it difficult for our oppossition to get their balls. The only robot design that is allowed to go after oppossition trackballs is a herder. So our design is a very robust herder with a great hybird program. We also decided that control was more valuable than speed in this role. We’ll see during the first few regionals if we’re right.
We collect scouting data for each machine that gives us a reasonable idea of how successful teams have been in their practice and qualifying matches at whatever they try to do. We’ll look at the number of hurdles attempted versus those completed and number of laps completed, among other things, and generate a picture of their robot’s capabilities based on that information.
This allows me to go into each strategy meeting with something better than a subject guess as to which machine is the best for the job. I typically formulate a strategy that best supports to most successful robot on the team, though rarely we’ll try something a bit more tricky. If your machine isn’t up to the task that you want to take it, I’ll know it and I’ll tell you. It may not always be the nicest thing to do, but it’s usually what’s best for the alliance.
There should be as little ambiguity as to a team’s role during a match as possible. Before ever getting out onto the field, all of the teams on our alliance will have an expectation as to how things should play out and a handful of contingency plans on top of that. I don’t like showboating and teams rarely make good decisions under pressure. If you didn’t have a strategy to beat the opposing alliance before the match started, you aren’t going to come up with it when there’s thirty seconds left in the match. I’m all about sticking to the plan.
can you post the link to the Q and A official answer?
How is negotiating with a potential ball hog any different than a “ramp hog” last year? It made sense for only one of the 3 robots to deploy the ramp; who should do it was based on each bot’s relative merits.
Granted there will be multiple opportunities to ball hog in a match, vs. the end-game aspect of ramps. But the strategy negotiations between alliance teams will be similar.
Footnote: Post 1000!
Because not everyone was lifting or ramping last year, i’d say maybe half at most were. So… this year, do you think theres going to be only half the teams interacting with the ball(s)? Id say something like 95% will be interacting with them…
Negotiations are one thing, but I think this game plays differently in that there are constant decisions throughout the entire match whether or not to pass on multiple scoring opportunities in lieu of your partners.
We’re talking a difference of scale here, not substance. There will likely be more opportunities to negotiate, I admit that. But the negotiations themselves won’t be much different than they were last year.
Fair enough, I agree. I thought the point of your original message was about an over-enthusiastic team member or coach who dominated the negotiations. We’ve always had to deal with that.
Hey Go Thunderhawks!!! I know you guys from being coach of the RoboDevils a few years back and from nationals last year.
We are designing for just such an eventuality… At nationals we hope to be part of a triumvarate that acquires the trackballs at the beginning of the game and passes them to each other over the overpass so that the trackball never hits the ground. To that end, we should be able to “catch” the ball another team puts across the overpass without crossing the line. One ball would be in transit the entire time while 2 robots are passing…
This could be very interesting to watch…and a real teamwork effort for an alliance and it is EXACTLY what (in my humble opinion) the GDC was thinking about when Woodie talked about being on the other side of complexity…
Of course I may be completely wrong.
I hope we can play with you guys at Nationals…
We will be there!!!
Good luck to everyone!!!
Bob Steele
We initially designed our bot to BE the ball hog slash galmour bot. It has a great way to capture an unpredictable ball. It has a great way to place the ball on the end, and a fast enough way to hurdle. It has a way to knock only our own alliance’s ball off the overpass in the beginning. No guts no glory right?
As it turns out, there are bots that are able to hurdle much better than us. We intend to support our alliance using any means necessary, including giving up the ball to a launcher. We all benefit when we use our most efficient methods to score, and I think everyone echos that sentiment for eliminations.
However, the question of whether or not another hurdler is “better” than us at hurdling will inevitably come up in seeding matches, especially in the early matches since we’ve never seen the other bots play. This will be a judgement call, on the spot. Even to the detriment of our own team, we’ll probably give up the ball in order to give another bot a chance while we simply play support. We do, after all, have ways to score that a launcher does not: reliable placement at the end. Knowing the competitiveness of the later matches though, this may not always be the case.
