Hi All
Joe public here, Has any teem conceded using a kicker to kick ball from the opponents side of the field
Back in to your side when you are full load ???
Good Look to you all
Hi All
I suspect that would be considered ‘controlling’ four balls.
Also, implementing a kicker for use only when you have three balls on board takes a fair bit of extra resource (design time, weight, physical space, etc.)
I do not think that many teams are going to use a kicker, but I would not be suprised if a team with a strong shooter will try to shoot from the other zone or tries to just eliminate the other alliances’s offensive strength. In other words a team with a strong offensive bot could also in this game be a strong defensive bot as well.
Hope everyone had a good build season and good luck at the competitions.
Correct.
G22:
Robots may only actively control three Basketballs at any time.
Violation: Foul per extra BasketballMoving or positioning a Basketball to gain advantage is considered actively controlling. Examples are “carrying” (holding Basketballs in the Robot), “herding” (intentionally pushing or impelling Basketballs to a desired location or direction) and “trapping” (pressing one or more Basketballs against a Court element in an attempt to shield them).
Also correct—no further support needed here.
Well spoted Duke461 I must get back to the rules.
Good luck to you all.
