Ball Pick-up
How many balls can your robot pick up (Not store) off the floor at one time?
OK perhaps I need to clarify due to confusion some people have had. The question is, if there was a clump of 30 balls (extremely unlikely) and your bot ran it over, in one pass how many would it collect? I apologize if my meaning wasn’t clear enough. I think that is clear enough.
Between 3 and 4.
I’m not sure what the question is asking… Is it asking how many your robot can pick up at one instant in time? (essentially the width of your pick-up mechanism) Or, is it asking for the capacity of your hopper?
We can pick up 4 instantaneously.
60+ over the match (if there is that many on the field!)
We can pick up two simultaneously, but it’s impossible for anyone to pick up more than 8 balls at once, unless they can compress them to a very small size before picking them up. 60in/7in ~ 8 balls.
Overall, the sky’s the limit. We don’t really know.
Twenty five poll options were probably not necessary here. Maybe categories like 0-3, 4-10, 10-20, 21+ would have been easier to analyze the results for.
I am confused. If this question is asking how many balls can be picked up simultaneously at one point in time like Tom said, you don’t need anywhere near 25 poll options.
If this poll is asking hopper capacity please search before you post.
Hopper Capacity
222’s Claw can simultaneously pick up three balls at a time and after our weight modifications hold 30-35 balls.
probably but I know our bot could easily pick up a dozen balls with our system. So I figured I would leave plenty of extra space because someone probably can pick up more because there is always someone better.
I think he’s asking “how many balls can you pick up and store in your robot”. I also think categories would have been better, because some people will be able to pick up more than 25.
actually I am asking at one time how many balls can your robot suck up off the ground. sorry if the wording wasn’t clear enough.
Our bot can pick up 2-3 balls at once. It can also hold 10+ balls in the hopper without problem.
-team 1852
if we pick up two, the conveyor wont grab them right and they get stuck so we only pick up 1
we have the ability to pick up 3 balls off the floor at one time if the balls are there.
Conveyor was designed for two balls at once, but is wide enough that it should be able to handle three at once and maybe even four.
If you are talking about how many balls you can pick up simultaneously, I am sore confused. Twenty-five balls at seven inches each is 175 linear inches of balls. Unless you can figure out some way to suck balls in from multiple sides at once you are mathematically restricted to a 60" length, which is eight balls.
I’m pretty sure you don’t understand your question.
We can pick up 2-3 balls at once. While testing our robot, we were able to feed 25 balls into our intake rollers in about 10-12 seconds.
i think that what he means is that when you pick up the balls(conveyor belt/lift) how many balls can said lifter hold?
our conveyor belt can hold 3 balls at a time but if 2 go in at the same time they get stuck.
our basket can hold 15.
Our rollers are only 2 balls wide, but the most we’ve tested for is 6 balls in the roller assembly at once.
yes that is pretty much what I am asking Thank you for re wording my question to help others understand because I feel that some were still confused even though I attempted to clarify I believe some were and maybe still are confused…
How about 0?
Tomasz Bania
Bleh, should have read the edited question first :wink:
We can only pick up one at a time.
