Ball placement in trench
Hi all,
The field drawings give specific information for the 3 balls before the wheel of fortune. However, I couldn’t anything about the two balls on the other side of the wheel of fortune. I was wondering if anyone has information on that, as it could be crucial during autonomous.
We had the same challenge. You can determine the distance from the initiation line (pg 4 of the layout doc). Then, there is a position for the “inside ball” that is based on the far wall. AFAIK there is no position info for the “outside ball”.
The manual in section 4.1.1.A.i says that the power cells are placed on the Trench Base Plates. The drawing for this part is GE-20123.
The part is 55.5 inches long and there are holes 18.5" from each edge. These holes are where the power cells will be placed by field reset.
Ahhh! Perfect! Thanks!
