While the brazing may well reduce impact loading by reducing the amount of space for “play” in the Double D, and could serve as an emergency fix, I would suggest holding off on doing it for the moment, if you can.
I would be concerned about getting proper alignment of the carrier plate while brazing… yes, it can be done, but if it is done wrong you are deeper in the hole.
I share your concern about hardening… or softening… of the shaft. You don’t want to weaken the shaft, yet at the same time you don’t want to make it brittle. While I can’t say for sure whether the brazing is likely to affect the shaft, or whether quenching would re-harden it, I agree with you that this is an unknown of no small concern.
I would be concerned that since the braze material is softer than the steel of the carrier plate that it will deform under static load, leaving you no further ahead than you were before brazing.
If a replacement carrier plate made of hardened steel becomes available it will likely be machined to fit the double-d of the shaft… which is now brazed into the old carrier plate.
I am hoping (rather anxiously now…) that the next team update from FIRST will address an official response to this problem, and that the official response will include replacement final stage carrier plates that will be available to all teams. (I am basing this on Dr. Joe’s comments that everyone at FIRST and Banebots is working hard to address this issue and the high respect I have for the FIRST organization… I have no inside knowledge on which to base this.)
So if you’ve got a spare transmission on which to test this fix, I’d say sure… go for it… and let us know how it works. It just might work out okay, after all. But if you can still test drive your robot, despite increasing backlash, and have no spares, then I would suggest perhaps waiting a day or two before trying this fix.
The optimal solution does seem to be in getting some proper carrier plates manufactured and distributed to teams so that the gearboxes can do the job that they were specified to do. It shouldn’t be that hard, nor that expensive, particularly if it is a co-ordinated response for all teams.
Jason
