Morris FIRST rookie team needs help!
We’re trying to find the Anderson Power Products battery connector online to order, and can’t seem to find it! If someone could help us, we’d really really appreciate it! Thank you!
Search on anderson power products or battery connector.
There are lots of sources documented in CD threads.
I tried to search Anderson, and we found the two-prong top to the cable we need, but I wasn’t able to find a place to purchase, let alone know which one is the correct one to order.
I just did a quick search of the Anderson website, and the store doesn’t allow you to buy the connectors as of today, let me know if this changes or if you have found another site to order from.
Search Chief Delphi, not google
THe battery cables in the KOP were provided by http://www.terminalsupplyco.com/
Are you looking for these?
Try here. They have the lowest prices we’ve seen for these connectors. (These are just the connector assemblies without the wires btw)
When you saw the picture, you were on the web page for AndyMark, A great company to work with. Just click on add to cart.
We thank you so much! We have been unable to continue work on our robot because of not being able to locate these parts, and now we can continue work. Thank you very much from the Morris Plaid Pillagers!
No problem. Glad I could help. You’re always only a click away from an answer. Chief Delphi rules.
If you are needing a cable for the robot or for a battery go here:
http://www.andymark.biz/am-0009.html
If you want just the parts here:
http://www.powerwerx.com/
or here:
http://www.helmarparts.com/Anderson_Connectors_SB_50_AMPS_s/115.htm
If you need a battery charger kit go here:
http://www.kellrobotics.org/index.php?option=com_microshop
