Hi, our team was wondering if the battery had to be in a up right postion on the robot or could it be at a side or an angle? We could not find anything in the manual.
Thanks for any help!::safety::
There is no orientation rule. There is however somewhere a rule that defines how long the battery wires to breaker can be before they count as official weight. (1ft i think?)
-Duke
Ok thank you so much!!
Out of curiostity do you know if we can have rope lights on our bots? like those xmas lights in a tube?
[R03-A], and 12" does in fact equal 1’. Note that this isn’t the length to breaker, however; it’s the length to the Anderson connector.
With respect to rope lights, I’d say those fall under Non-Functional Decoration and suggest looking at those rules.
In reply to battery orientation there are two aspects to take into account for a correct answer here, battery specs and robot rules.
For the battery specs, because it is an AGM battery, you can place the batteries in any orientation and not have a diminished performance because of the orientation. As for the game and robot rules, there are no rules to restrict you from placing the battery in any orientation on you robot, but i will give you the following recommendations for best performance on the robot.
Also a couple good practices to prolong the life and performance of the batteries are:
Obviously these are not all inclusive lists but good practices with respect to the battery.
You can, just make sure to abide by [R05] and [R08] (i.e. don’t put them on a shiny disco ball).
[/li]For the same reason, don’t install the battery upside down. Any other direction (upright, on its side, flat) is fine.
If one reads the manufacturer’s sheet on this battery it would lead to believe that you can mount and use the battery in any orientation. I would suggest that upside down is a bad idea because you can’t see the insulation that should cover the terminals and you can’t see if the terminals are under stress. Please remember that the metal terminal that is sticking out of the red and black plastic on your battery is simply soldered to a round terminal inside the battery. Any stress can damage or break this connection. This is not a repairable fault. While the batteries we use are AGM and theoretically have the acid impregnated in a glass mat, I recommend that teams do not charge them upside down. This is just good practice to prevent some of the problems already listed.
I believe so, Last year we had leds, in our back panel of lexan. I would check the rules for sure. but make sure that it wont get caught in any moving parts or other robots for that matter.
-Thomas
Gel and AGM are different technologies.
Whoops, thank you for pointing out the typo, updated.
Everyone knows not to put the battery in upside down. All the electrons will fall out when you disconnect it. Or is that what that AndyMark plastic plug is for?
Actually its not far from the truth… in 2010 our battery was installed with a downward slope (Terminals downward made the cable connection run much shorter) Well lo and behold after one match we noticed something that looked little damp in the battery carrier after removing the battery… Very carefully we checked with a little bit of baking soda and yup the battery had leaked. From that point on batteries are always right side up. Having a leaky battery is not something you want to deal with during competition.
I wouldn’t stress a few extra inches of #6 wire to make for better mounting. 1000’ of #6 wire has a resistance 0.3951 ohms. Even at a 50 amp draw, 6’ of #6 gauge wire has less than 0.25 volts drop. I’m not saying be wasteful by any means, just that if you need an extra inch or two to make a better robot, it’s worth taking it. Go here to play with values to see what your losses will be:
http://genuinedealz.com/voltage-drop.html
-Mike
Mike,
In reality the rule of thumb is 2 feet of #6 will drop 0.1 volt at 100 amps. Stall current on a CIM is 133 amps. Four CIMs pushing against the player station, for example, (stalled) will drop 0.5 volts before calculating in the drop across the internal resistance of the battery or considering a battery that is no longer at full charge. Remember that is all the wire, black and red, in the path.
Gary,
Don’t you carry and electron cleanup kit? We do.
Polyester picks up electrons. (Low on the Triboelectric Series)
Are you asking if I can pick up electrons? I’m positive.
Yea I know that! But it gets messy! What do you do when you get grounded?
I happen to think Gary is pretty well grounded. You too, Al.
