These are designed as a slip fit and are geometrically held in place when the module is assembled. If you want to keep them in place during assembly you can use loctite 603/638/648.
*Could also use super glue if you really wanted to as well.
It’s not letting it sit flush with the other stuff and allowing movement even when fully assembled that’s my main concern because with the other two we have built right now it was a easy slip on fit and doesn’t move now
Red → Snap ring if you want to retain it together so it doesn’t move
Orange → Spacer included so its flush against the bearing
Green → Built in spacer
Blue → Gear Cartridge built in spacer
In this configuration the bearings have no where to go. Do you have pictures or more information? Also if you email [email protected], one of the application engineers can verify all the information and walk you through it.
