Belt For Fisher Price Motor
Does Anybody Know what belt is good to use on the Fisher Price Motor 00968-9002?
Check online to find your local Gates Rubber Power transmission products dealer. The belt is 15mm wide with a 3mm pitch and comes in a number of circumferences ( read belt length) measured in mm. I needed a belt approximately 300mm in length. They also sell the matching sprockets for the driven end of your belted drive train again with 15mm width and 3mm pitch. The motor sprocket is 16 tooth so any multiple of 16 gives the desired gear reduction ratio. I.E. 16:48 is 1:4 reduction ratio. I ordered my locally through Motion Industries and will take 5-7working days for delivery. Hope this helps out. Best wishes, LRU.
I believe you’re referring to the CIM motor. The FP motor comes with a gear, not pulley on it’s output shaft.
Furthermore, I don’t even see a motor with the model number that the original post references.
The new CIM motor is also a Fisher Price motor.
Yes, but it doesn’t have that model number. The minibike motor is FR801-005
Please search before you post. I posted this last week. Look here
-Paul
Some Powergrip GT2 belts can also be used with HTP toothed pulleys. Does anyone know if this is true with the 3 mm pitch, or only the 5 mm and up?
\I mean the one with the pulley on it
This thread helped me order some belts through a Gates distributor. Where can I get compatible pulley’s for a 5/8" keyed shaft? We don’t have access to a machine shop. All we have is a drill press and a band saw.
I found some on sdp-si.com. You have to seach for the bore size in decimal (.625)…
https://sdp-si.com/eStore/
FYI …
found a source for “HTD3” 3mm pitch belts](http://www.econobelt.com/Q460/RFQ/default.asp?Page=tbelt/08.htm) in 15mm width. Check Quality Transmission Components. They also carry an assortment of matching pulleys and tensioners (pully width limited to 9mm ?). Their website could use some help, but hopefully a phone call will get you what you need. I don’t know about their stock or delivery capabilities - hope to find out tomorrow.
