Well, that was a long title.
Two months ago I had an idea (and a challenge) to make a COTS-compatible belt in-tube elevator.
The main constraint was that teams had to be able to manufacture a continuous elevator with no tube CNC and just a band saw and a vendor kit.
My first iteration revolved around giant billet bearing blocks, which wasn’t workable. (Thank you to @thevedantin for trying to make it workable)
Bearing Blocks
When REV came out with their new clamping bearing block, I decided to make a V2 centered around that design. The bearing block is built with two 3/16" plates, REV clamping bearing blocks, and a 3dp crush block connecting them.
The idler stackup is stolen from @Nick_Coussens. It uses a 19mm od tube as the idler body, with washers on the outside. I elected to go this route rather than use printed pulleys to ensure that they would never fail.
Gearbox
The gearbox is powered by MAXPlanetaries and supports 24-36t pulleys, allowing for a large range of reductions (in inches per revolution):
- 5:1: 1.88-2.83
- 9:1: 1.04-1.57
- 12:1: 0.78-1.18
This ranges from the gearing 8096 used in their 2023 elevator to climb, to the gearing 4414 used in their 2023 elevator to score suuuper fast.
The gearbox is built to support elevator widths between 13" and infinity inches. All you need to do is change the length of the tube connecting it to the idler.
Idler
The redirect idlers go into the tube for strength.
Tensioning
The elevator is tensioned on the top of the carriage with a WCP cam. You would need to drill out some of the holes at the top of this tube for clearance for the bolts.
The belt is secured on the down line by a simple plate. Use a different configuration depending on the width of the carriage.
For the down belt, I had to cut a 1.25" hole out with a hole saw.
I wanted to also have a configurable 3 stage elevator in this document, but I didn’t have the time to make that. Everything needed for infinite stages is in the document, however. In the future, I want to make a new iteration with 0.25" stage gaps and better bearing overlap.
CAD
Thank you to @hanoop, @thevedantin, and @Nick_Coussens (and a lot of other people) for giving me such good feedback on this design!
