Best Battery Chargers 2016
Hi, did you add Anderson connectors to the ends of these or just use the clamps for charging?
We added Anderson connectors to them and plug them directly into batteries.
We got a Noco Genius G4 6V/12V 4 Bank charger at the beginning of last year. It is a little expensive, but is slightly cheaper than the Andymark 3 bank charger. (Also, it was on sale for about $75 off when we got it)
I like Black & Decker. I have BM3B model and I am satisfied with it.:cool: Good battery charger with a good rating. Recommend
I can’t see a 1.5amp charger being effective when wanting to charge batteries quickly at a competition, you should aim for something in the 4-6amp range.
I bought a VDC BatteryMINder desulphator. I’ve had some success with it but I’ve also had batteries that just didn’t come back. I’ve had as much luck with this charger. It’s the best all around charger I’ve ever owned. It doesn’t over charge your battery, will tell you how well your charging system is working on your car, gives you a percentage of how much of a charge your battery has taken, among other things.
