Working on coding our robot to be able to drive straight using a gyroscope. The gyroscope initializes at the beginning of the map, getting it’s initial heading. Now, I want the robot to at the press of a button be able to turn back to that orientation. I think I’ve finally structured the code below correctly. Questions:
Am I correct in assuming that when I enable PID in my DriveStraight command by writing enable(); that the robot will start doing what is written in the usePidOutput method?
What will the bounds of the “output” variable be? I know it’s a finely tuned variable of the error between my gyro heading and my desired heading of 0, but I don’t know if I can plug it into my motors or not.
I apologize in advance if there’s a topic that answers this question. If that’s the case, please just link me.Thanks in advance for your help.
@author Developer
public class DriveSystem extends PIDSubsystem {
private static final double Kp = 3;
private static final double Ki = 0.2;
private static final double Kd = 0.1;
RobotDrive drive= new RobotDrive(RobotMap.LeftDrive, RobotMap.RightDrive);
Gyro gyro = new Gyro(RobotMap.gyroPort);
// Initialize your subsystem here
public DriveSystem() {
[INDENT]super(“DriveSystem”, Kp, Ki, Kd);
setSetpoint(0);
// Use these to get going:
// setSetpoint() - Sets where the PID controller should move the system
// to
// enable() - Enables the PID controller.
public void initDefaultCommand() {
// Set the default command for a subsystem here.
//setDefaultCommand(new MySpecialCommand());
setDefaultCommand(new DriveWithJoysticks());
protected double returnPIDInput() {
// Return your input value for the PID loop
// e.g. a sensor, like a potentiometer:
// yourPot.getAverageVoltage() / kYourMaxVoltage;
return gyro.getAngle();
protected void usePIDOutput(double output) {
// Use output to drive your system, like a motor
// e.g. yourMotor.set(output);
if (gyro.getAngle() > 1) {
DriveReg(0, output);
if (gyro.getAngle() < -1){
DriveReg(output, 0);
drive.tankDrive(.5,.5);
Not like a potentiometer. See bolded portions below:
* Return the actual angle in degrees that the robot is currently facing.
* The angle is based on the current accumulator value corrected by the oversampling rate, the
* gyro type and the A/D calibration values.
* **The angle is continuous, that is can go beyond 360 degrees.** This make algorithms that wouldn't
* want to see a discontinuity in the gyro output as it sweeps past 0 on the second time around.
* @return the current heading of the robot in degrees. This heading is based on integration
* of the returned rate from the gyro.
float **Gyro::GetAngle( void )**
Note that ProjectZero has not been on Chief Delphi in over a year.
The P, I, and D gains are usually determined through a bit of math and a lot of trial and error once the hardware is running. If you search Chief Delphi on “PID Drivetrain Tuning” you will turn up a few good threads that take you through several schools of how to determine your optimum PID values.
Note that when you add/subtract (or even move) weight to your robot, you will want to adjust (or at least verify) your PID constants.
