I have been designing a custom two speed gearbox, and I have a question regarding the dimensions of the bimba cylinders.
What is the total length of this bimba cylinder while fully retracted? Fully extended?
What exactly is the difference between these two bimba cylinders?
Does the latter maintain an extended position when no air is pumped into the cylinder? If so, can the spring-style cylinder be used as a fail safe, in the event that the pneumatic system ruptures or the robot is undergoing a stall load situation?
One is spring return. You only need to put air in one direction. We have tried these in the past, the issue is that when shifting back in with the spring, the two sides don’t spring right. And most of the time you don’t have enough “spring” to shift under load.
For what its worth and how much air your consuming, your better off with the normal cylinder.
I was planning on using this exact cylinder. However, I’ve been having problems understanding how the Poofs (254) have used this piston mount interfaced with the cylinder as you listed above to connect to the dog.
Since this piston mount seems to mount directly to the side plate, how does the piston connect to the dog gear? (On the super shifter, there is a big spacing between the face of the cylinder and the rod that connects the dog to the cylinder.
Basically how 254 does it. They use that cylinder and it nose mounts/threads into that piston mount. From there it threads into a cone that pulls the rod that pulls the dog.
The only difference between 254’s and the AM one is that this guy threads into a block while AM’s requires a nut. Both setups do the same thing mechanically.
Here is a CAD file that should help you design the mount for the cylinder.
I haven’t had a chance to look through it, but I think that it’s the right one.
