Does anyone know if it’s possible to use binary numbers in C? Of course, it’s just to make it easier to read the source. I’m doing some bitwise operations and 218 or 0xDA just isn’t as meaningful as 11011010.
I don’t believe the C standards have any support for entering numbers in binary. Just use hex - it’ll be awkward for a bit but after a while you’ll be able to read hex and “see” the binary without any trouble. Binary becomes cumbersome when you start talking about 16 and 32 bit (and larger) numbers too.
Most people who write a lot of software will tell you that 0xDA is much easier to read than 11011010.
I’m 1200 miles from my K&R right now…
0b11011010
should be equivalent to
0xDA
N’est-ce pas?
That’s what I thought at first too, but gcc didn’t seem to like it, and I found several discussions on some C newsgroups that suggested that binary constants aren’t officially part of the language. However, I just checked it and MCC18 seemed to take it…
My advice still applies though: get used to hex, it’s what everyone else uses
So apparently you can’t, unless the C18 compiler is different in that aspect (it isn’t a 100% ANSI C, after all) - assuming you are asking this about the Microchip compiler.
I agree with Dave that the hexadecimal form is much better once you get used to it.
You probably know it, but for the ones that do not, each hex symbol represents 4 bits. Once you realize that, it just isn’t magic anymore.
0b should work. It’s not ANSI C, but many compilers understand it. gcc compiles it fine. Dunno about C18 - I usually go out of my way to avoid binary.
http://refcards.com/refcards/c/c-refcard-letter.pdf
George
Well, I’m using SDCC. I’d use C18, but it doesn’t work for the 16F series PICs. I just tried 0b and it didn’t like it. I guess I’ll have to stick to hex or decimal.
The gcc port for Atmel AVRs supports it no questions asked, it’s actually fairly used in the examples I saw so 0b works there…
No support in SDCC? Darn I was gonna use it for this 16F I got sitting here. Oh well…
I sometimes use a calculator to convert from binary to hex and then write the binary equivalent in a comment by the hexadecimal value. For example:
int bit2mask = 0x04; //00000100b
#define b00000000 0x00
#define b00000001 0x01
#define b00000010 0x02
#define b00000011 0x03
#define b11111110 0xFE
#define b11111111 0xFF
Generate 256 lines once, then let the preprocessor take care of it for you from then on.
