Blinking Red Light
Hey,
Code uploads, and works without the camera code… on the other hand… when the camera code is added… it’ll upload and the program state will blink as well on the I/O…it will flash red on code error… any hints on why this is happening??:slight_smile:
Ps… controller is either 2005, 2006… doesnt say on controller
you need to find out which controller it is, the camera code uses some libraries that need to be correct for the PIC inside, try reading the txt file included about using a previous years RC and see if that works.
Yes i think that will work cuz i just uploaded the old 2005 code … and it works with the camera and everything… thanxs for the help:)
When you run IFI Loader and do a Controller Verify it should tell you what controller it is.
Ye i do that but it doesnt say wat it is… it just says version and FRC
also i keep getting this error’
MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Error - processor types do not agree across all input files.
Errors : 1
BUILD FAILED: Thu Dec 21 17:14:28 2006
Did you follow all the instructions on using last years RC as I’m pretty sure that you have an 05?
Mostly likely that i do. do u have the txt file that explains how to change the linker files or w.e? plz and thxs:)
There you go
awesome thxs alot:)
