"Blinking" Spark Max Controllers from the Spark Max Client
Hello again Chiefdelphi,
When using the new USB to CAN function on the Spark Max Client, I have found that there is no definite way to know exactly which device in your array you are configuring as far as l can tell. Is anyone aware if any function is available by which I can “blink” or perform a similar action to identify devices in my system on the program?
Thanks as always!
Bump
At the top of the client there is a drop down to choose which one you want to configure.
Yes, after you’ve connected to one of the SparkMax’s in the CAN chain, the Network tab will list the devices.
In the column between CAN ID and Firmware is a rosette.
Click on that and the corresponding Spark Max will rapid blink.
Back when this thread was made that didn’t exist.
Yep, but it does exist now for the new OP Bump.
