I think that the head ref needs to be very strict about the rule a be willing to give out many red cards to team in quals and elims with a call going strait to a red card for a violation. sure it might be to many cards given out but a offence such as blockading. This is just my personal opinion and may not reflect what other members of my team think.
Is the Intent Valid?
I don’t think anyone can argue that making it impossible to score for an alliance shouldn’t be penalized, so yes this type of play should be regulated.Should the intent be adjusted?
Here is where more of an argument can be made, and where there seems to be a lot of confusion. Some will argue that preventing one robot from scoring at all is also the intent of the rules/should be the intent of the rules
I’ll make the argument. In every good team sport defense is as valid as offense. If we over react to this issue, we could end up defining a new rule that gives every robot the right to score and turns future matches into six individual games played on the same field. Put a time limit on “blockading” calls (whatever those are) the same way we put time limits on pins, and the problem takes care of itself.
Is blockading even a necessary rule to exist? Imagine you have your 3 robots near your exchange and the opposing alliance has robots in the two lanes on either side of the switch, blocking you.
Why is this a bad thing? Quite obviously, FIRST is okay with defense, otherwise the null zones would have been bigger and there would have been more protected zones on the field. So why is “blockading” a bad thing? If you have made the strategical mistake of putting all 3 robots in that area at the same time, and you also do not have a robot that can push through either of the opponent robots… why should the opponent be punished for taking advantage of the situation?
I really like this idea. I think I would be fine with blockading as long as you couldn’t do it for an extended period of time. I think calling it like a pin is pretty fair as the end result of blockading vs pinning is similar.
I understand the argument that blockading is strategic but pinning is also strategic. The reason both have limits and rules is to promote more offensive play which I believe has been a good thing the last couple of years. It’s not necessarily about shutting down a robot/alliance but slowing them down to give your alliance an edge.
So in a match where we’ll say both alliances have robots of skill values 10,1,1, you believe that its acceptable that both alliances use their 2 low skill robots to prevent the high skill robots from scoring at all? Is this really what you want to see? Is this encouraging good engineering? How about if you’re on the 10 team? Do you feel like your engineering efforts mattered if you can just be excluded from playing the game?
Preventing a single robot from being able to play the game is not right. Even if it takes 3 robots to do it. Just because you win does not mean that its a positive lesson for your students. Do not bring others down to lift yourself up.
If all 3 teams on the alliance agrees to the strat, and it fits within the rules, yes?
The part you quoted from Brennan is flawed anyways though. To me, the part of the rule he is referencing to is only giving an example of the violation, not the only way its broken.
Yes and yes.
I don’t think engineering is in question here. People don’t want to build level 1 robot skill robots. People want to be able to build 10 level robots. I’ve never personally been on a team with a level 10 robot, but maybe an 8 would be a reasonable assessment of my best robot (2018), and no, I wouldn’t feel bad if two level 1 robots stopped us from scoring.
Nope, i’d just call it good defense/strategy, and work with our drivers on those scenarios.
Could you elaborate more on what makes it not right? Is lock down defense bad? Should defense be banned? Should the best robot always win regardless of driver ability or strategic skill? How does playing a different strategy that is common in every sport I can think of invalid in the context of FRC?
I think you want some degree of counter play to every strategy. It’s the same reason FRC actively avoids creating choke hold strategies, and rules them out to the best of their abilities. I don’t think blockading should be called unless there is almost no counter play. Much like pinning, when you are pinned there is no counter play, your robot is pinned, the other robot can push you. Nothing you can do.
This thread is trying to approach the problem less from “is it legal now” and more of “should it be legal” and “how could the rule be modified”
This is an interesting idea. How would a referee indicate this time limit?
Very disagreeing with you here. FRC is a sport, not a science fair. If you want to be a “10”, you need to do more than just have good engineering. You also need to have:
- good driving (practice against defense)
- good strategy (defense-resistant, or defense aware scoring. Counter defense as an alliance)
- a design that as much as possible is resistant to defense (holds gamepiece inside frame perimeter, can push / resist pins)
I invite you to think about the game from the perspective of the "1"s. Just because they don’t have the resources of the "10"s, doesn’t mean they don’t have the right to gameplay that might even the odds. A win through plucky defense can be every bit as inspiring to those students (and to the audience) as a win would be for any team (and certainly more inspiring than a rule which forces them to sit in the corner and lose).
With a hand wave countdown probably, same as a pin. The “blockading” (as interpreted by the ref) might be accidental anyway, so the handwave would give the offending alliance time to correct before the cards start flying.
Pinning could be redefined to encompass what we already know as pinning as well as the concepts of “trapping” and blockading.
Personally my approach is to discourage certain types of game play through game design as opposed to rule enforcement. To minimize the incentives for blockades games shoukd eliminate choke points on the field, spread out multiple scoring and loading areas, and provide plenty of achievable offensive incentives for robots of varying skill levels.
I had the impression that “No colluding to shut down major elements of game play” was intended as a catch-all rule in case someone finds a design or strategy that “breaks” the game (offensively or defensively). That’s why the penalty is straight to cards.
The FTC game a few years ago (Velocity Vortex) had an opportunity for teams to design a closed loop scoring mechanism (the game also had alliance specific scoring elements). When asked about the legality in QA the response was closed loop scoring constituted shutting down major elements of game play because your alliance partner would be denied access to the scoring elements.
Because I pay $5000 to get 10 plays at a regional and the opposing alliance being able to prevent me from playing at all goes against the point of FIRST. Lockdown defense is bad, and obviously FIRST agrees because we have a pinning rule. Your argument is strictly that blockading isn’t as bad as pinning, and I’m saying they’re the same. Obviously defense should not be banned but what is “defense”? This is not allowed in every sport. Compare blockading/pinning to holding in football. You’re saying that because your line isn’t good enough to stop my DE that you should be allowed to hold my DE from playing. Football is literally nothing but “you can slow me down but not prevent me from playing” penalties.
There is no counterplay to blockading. It is the same as pinning. That’s the point, you are trapped.
As I explain further up real sports do not allow this behavior either. Blockading/Pinning is not “plucky defense”. Its an unanswerable way to prevent someone from playing the game. And whatever nonsense you’re saying about “you should always design to push other robots” is ridiculous. I’d bet you whatever amount of money you want that you could not build a robot that could push 1817 sideways this year. Because of the physical limitations of our KOP, its possible to build un-pushable robots. Defensive robots in FRC already have all the advantages they should be afforded, allowing them prevent a robot from competing with no counterplay should not be allowed. Blockading is no different from pinning except that it has not gotten the attention it deserves over the last decade, and I’m glad that it’s finally been brought to light.
In the real world matches I have seen, the skill value 1 & 2 robots play defense a the skill value 1 & 2 level and the skill level 8 & 9 robots play anti-defense at the 8 & 9 level so blockade does not persist for very long.
In instances where truly “plucky defense” was played, the team may have had a level 1 or 2 robot but it was driven by a driver at a much higher skill level.
Blockading is an equalizer. It literally just requires you to sit sideways.
So 3310 couldnt of been putting cubes in the switch, assuming we use the example from Finals 3? That doing something. Does that mean it wasnt blockading?
At least with pinning there isint much you could do besides break more rules (like shoving your intake into their bot or needlessly slamming)
I really don’t think that “lock down” defense is really as simple to pull off and game breaking as some people do. Remember - every robot playing defense is not scoring, and not otherwise protecting its own alliance-mates from defense.
That said, I’m arguing the issue from one far pole, against the other pole that robots should not be prevented from doing their offensive thing. Rules that discourage almost all defense are bad imo because they contribute to the performance inequality and make games boring. But the balance is always in between. I’m open to the idea of some kind of time limit on holds / catch-all don’t break the game rule as long as it’s defined in a way that it’s not constantly called, because the last thing we need is more matches decided by refs. That will make the cure worse than the disease.
I’d be very much in favor of a timed countdown for blockading. Right now blockading has to be interpreted by the refs as preventing gameplay for an unspecified length of time and you instantly go from no penalty to a massive one. Having the Head Ref count it and knowing you have a few seconds to rectify your positioning would avoid accidental calls on alliances that inadvertently blockade while executing a different strategy.
I’m going to challenge the first part of this statement. If preventing a single robot from playing the game is not right then all defense is inherently not okay. Our team (and others) won matches in 2017 by preventing a robot from climbing by trapping them behind an airship. No pinning, no blockading, just our robot keeping even with them so they couldn’t get by. If that’s not a valid strategy then every game should be 2015 or 2001 (which were terrible game designs btw). The blockading rule already handles shutting down all of a scoring method for opponents, I don’t see how you can reasonably write a single robot defense rule that wouldn’t end up making really good 1v1 defense illegal.
I think we have differing views on effective defense. There are ways to play lockdown defense that aren’t pinning. I will direct you to my original example of blockading in my OP, where in this thought experiment where a driver because he/she are skilled was able to get out of the blockade, while the other was not, even though the blockading alliance did the exact same thing. There is counterplay to blockading, it’s outplaying the defending driver without running to the other side. Hundreds of teams did this hundreds of times over the course of many many FRC seasons… All you need to do is watch a few matches to see that good defense takes some immense skill, and is not trivial to pull off against another competent driver.
This statement is just completely ignorant of the skill level it takes to play positional defense. If all good defense required is sitting sideways, everyone would be doing it, and all the top engineered robots would be constantly losing matches due to not being able to score in teleop. It is an equalizer, but it does require non-trivial skill to execute.
The middle ground that Brendan is proposing seems like a justifiable middle ground where it is clear when “teaming up” on a top level team is occurring, and limiting the teaming up. We still have to define what blockading is, and what it isn’t, which isn’t abundantly clear. Like Karthik mentioned, designing with blockading in mind is important, but not always possible, so doing some combination of both would probably be ideal.
I don’t like the blockading rule as written, but I think the intent of the rule has value. Consider the scenario:
Blue Alliance:
1 Very strong robot
2 Weak robots.
Red Alliance:
3 Medium strength robots
Now on paper, this is probably a pretty fair match. The strong robot has to make up for it’s weaker teammates and can probably expect some tough defense. It’s a recipe for an exciting match. However, if we have no blockading rule, the best strategy is for Red to send its 2 weakest bots to box the strong robot on Blue into a corner and let it’s remaining teammate outscore the 2 weak robots. Now this is a legit strategy, but the result is a very boring match. The students on the Blue alliance are frustrated because they don’t get to use the cool robot they worked hard on, instead spending their time going back and forth trying to escape. 2/3 of the students on the Red alliance aren’t even trying to play the actual game, instead just trying to be roadblocks as effectively as possible, and probably aren’t having a great time either, even if they win.
If the rules lead to a situation where the optimal strategy is very boring or frustrating for everyone involved, it’s best to change the rules. Consider the sport of basketball. Originally, there was no shot clock, and as a result the game devolved into getting a small lead, and trying to play as defensively as possible passing the ball back and forth to run out the clock. It was legal and the optimal strategy, but very boring and made the sport unpopular. The shot clock was added and play sped up dramatically leading to one of the world’s most popular sports.
I think the blockading rule makes the game better at the average level of play, which is very different from the Cheezy Champs, IRI, or Einstein level of play.
As for the rule as written, there are a lot of problems. The last two years, obstructions on the field has made blockading very easy to perform, but also very easy to accomplish accidentally. The rule requires refs to make a judgement call about what the robots are doing, and whether or not a part of the field is “closed off” which can come down to the capabilities of the robot(s) being blockaded. Refs are always going to be more hesitant to make calls that require judgement then calls that require you to have seen a thing happen. Did Robot A touch Robot B is easy, did Robot A MEAN to touch Robot B is hard.
Considering the rule’s subjective nature, I think teams need a warning system during the match similar to pinning. Teams have a chance to see the pinning count and back off, even if their definition of pinning does not agree with the refs. This is presumably why it is a yellow card currently, as a yellow is a warning, but I think that has it’s own problem.
A yellow card (in my opinion) should not be given as the only penalty for infractions that can skew the outcome of the match. If you do that, it gives the opportunity for teams to decided to take the yellow card in exchange for securing a particularly clutch match. The yellow card should be paired with either a points penalty, a DQ, or a replay.
In the ideal world, the game is designed such that blockading can not be easily accomplished and it is obvious when it is happening, but that is not always possible considering all the competing interests in designing a game.
Having blockade as a yellow card offense makes referees call it less often. I think we’d be better off if it was a foul instead. It could escalate to a yellow or red card at the referees’ discretion. This would make it easier for human referees to call a blockade that they feel 85% sure about. It doesn’t automatically swing the match that way.
Having the penalty called once in a while is better at deterring teams from doing defense that makes matches boring and unfun.
I don’t mind the rule as written in 2018. It describes the idea of what they are trying to prevent. Giving referees more options on calling it might help, and I like nuclearnerd’s idea of a visible count similar to what we have with pinning. That allows teams to get feedback without an actual penalty or card if they back off soon enough.
