I am a new programmer with just the most basic understanding of code, and I heard the controls for next year include using bluetooth.
Now I know that “officialy” you can’t say yes, if that is a rumor that is being used to intimidate then it’s working well :yikes: but if confirmation is available then I will ladly accept it.
I didn’t go but I think that’s where the speculation came from and each year is a challenge so I think it would fit right in to their plans, whatever they are
According to the FAQ, Bluetooth isn’t currently listed as a programming method.
From the document found here:
Q What type of communication does the system use?
A The new system uses proven **802.11 **wireless communications. More features are being considered for future expansion including robot-to-robot direct wireless communications and wireless joystick operation.
Q Must they be tethered in order to apply/change certain settings?
A No, the new system will include the ability to do wireless programming. However, this may not be allowed in competitions (in the PITS) to avoid wireless contention with the field.
Q Will the new controller be programmable through a USB 1.1 or USB 2.0 port?
A No, it will use an Ethernet connection.
Q How do I download code to the controller?
A Using either LabVIEW or the WindRiver Workbench tools over a much faster wireless connection.
This doesn’t eliminate the possibility of Bluetooth, but… I’d say it’s unlikely.
The NXT unit (used by FTC and FLL) is Bluetooth-capable. The FRC controller isn’t the NXT, though.
Using WiFi, pretty much eliminates the possibility of Bluetooth. They both operate in the 2.4GHz band and thus interfere with each other. I would not want to operate a Bluetooth device in an environment with what could be 6 or more channels of WiFi (or as low as 2 channels). Bluetooth frequency hops around the whole spectrum but with that many active channels there is no open frequencies. Hopefully the FRC/FTC(NXT) interference can be minimized by good floor planning. Maybe the WiFi will run in Bluetooth friendly mode.
Since the NI controller doesn’t have a bluetooth receiver, would it be possible to put some kind of bluetooth-to-ethernet adapter on the operator interface to send the signals to the bot?
i don’t about blue tooth, but as long as there is wireless program transfer onto the robot, i am more than pleased. no more being yelled at or yelling at random people standing next to the robot to hit program and run from the robot.
