Break while updating wpilib
When I was updating my WPILib for 3.0 to 4.0, my internet connection broke for a while and I found that the updating process failed. But when I was trying to update it again after the internet is on, it said “no WPILib update found”.
I am just wondering what is myWPILib version currently and will this update failure affect my programing? If my version is still 3.0, what can I do if I want to update to 4.0?
WPILib is an offline installer, meaning after you download the .iso from GitHub you should no longer need an internet connection. If you think the update failed, then I would make sure the WPILib JDK is not in use (remove it from JAVA_HOME and PATH if it is there), restart your computer, then try it again to see if you get another error.
