breaking the minibot/ controled descent
what is the best way to safely stop the minibot at the top of the pole or put it in a controled descent. please give me a good explanation. danke.
-ethan and 3585
See this thread http://www.chiefdelphi.com/forums/showthread.php?threadid=93876
Most methods involve increasing friction on the poles greatly. That can be done when the normal force on the pole by the wheels is greater. However, when doing that it usually makes it slower. Not saying the normal force and friction is completely bad, but theres a fine line.
In all honesty, your minibot should be fine if it falls back down.
If your’re really concerned, put foam or some cushioning support on your deployer so that when it comes back down it softly lands into that.
Hope This Helps,
-Duke
The best way, we found, for a controlled descent, is to make the motor act as a brake on the way down.
To do this you need to connect the positive pole of the battery to both electrical connections of the motor, during descent. Use a light switch that gets switched when the minibot hits the top to do this.
Basically, have the lightswitch change the connections on the motor from + and - to + and +.
Actually, it has nothing to do with connecting the motor to (+) but rather, shorting the leads to the motor so that as it backdrives down the pole it acts as a generator. With the dead short on the “generator output” it resists rotation.
haha, the title of this thread confused me at first… you said “breaking” instead of “braking” :rolleyes:
We implemented a circuit that switched the motors from driven to “braking” via a short when it reaches the top, here is a video: http://www.youtube.com/watch?v=KEXraq_Tmy0
we broke 3 gearboxes on our minibot from it hitting the bottom when it came back down. A little surgical tubing as padding works nicely!
Correct it is turning the motor into a generator that creates the dynamic braking effect.
Most teams short it via the (-) side of the circuit rather than the (+) side, though both ways will do the same thing.
My understanding (and I may be wrong, it’s been a while since I’ce studies regenerative braking) was that connecting the (-) sides together dissipated the energy as heat in the motor while connecting the (+) to both sides would dissipate the energy by recharging the battery. Am I incorrect in this? and if I’m not wouldn’t it be better not to heat an already heated motor?
Regardless of which side you connect, the battery is not part of the completed circuit and thus no current flows in or out of it. All energy dissipation occurs in the motor and the wiring/components that are shorting the leads.
Daniel,
By shorting the motor leads together, you cause all generated currents to flow in the short and no where else. It does not matter whether the the positive or negative lead of the battery is connected at all. No current will flow through the battery when the motor leads are shorted. This method is identical to the the “brake” mode on either the Victor or Jag. The amount of current generated and the amount of braking action is RPM dependent. The faster the motor is spinning the more braking is evident.
