Broach for NEO Motor Shaft
Does anyone know where to get a broach for the NEO? It would be nice to not have to rely on only setscrews or friction if possible.
The Neo uses an 8mm shaft with a 2mm keyway, which is a standard size. Broaches for this should be readily available, such as McMaster part 8805A11
We have the one from McMaster. Super useful and you don’t need nearly as large a press as a hex broach.
Thanks. Is there a collar/guide that you have to use with this one like there are for some of the larger brooches?
Yes, as far as I’m aware all key way broaches need bushings.
That’s what I was thinking. Do you have a link to a bushing that will work?
It’s McMaster all the way down. 8805A11 and 8804A71
FYI, for those special weird situations where you can’t broach it, you can use a 2mm end mill and go in the end of the shaft to make a short keyway with a blind hole.
For -really- nutty things, you can use a 2mm slitting saw to make a slot in the side of a hex shaft to get a long keyway on a shaft that doesn’t have a through hole. You need a custom key that is taller to avoid having it fall out. I had to make this because my kiddos painted themselves into a corner on an intake/shooter.
Broaches are the best way, of course!
BTW, you CAN make a Kraken spline hole on a long shaft. I don’t reccomend it, though. Don’t put it on a robot, especially if all you have is churro stock on hand :frowning: Drill in the motor end with 7mm. Drill in the other end with an 8mm. Leave NO MORE than 3/4" of 7mm!!! Seriously! Broach part way, tap out backwards. Repeat 3 times. Curse.
this is seriously impressive. We just 3D printed a hex adapter from WCP instead, and I was surprised how well PLA held up but this idea takes the jank to a whole new level. I love it!
