I notice your use of Vista. That could be problem number one. Try getting a machine with XP loaded onto it, and installing a fresh copy of the loader. My guess is that your problem has something to do with how Vista is handling your COM port.
This definitely smacks of a communication problem, rather than a problem with the IFI hardware. I would recommend trying either a different USB/serial adapter or a different computer, and see if any of this behavior changes.
I have tried this with both a REAL com port, running windows XP, the usb -> Serial adapter running windows xp and the adapter running vista… all have the same problem.
I had it working for a while after i posted the video, might have sent code about 10 times or so and then it just stopped working half way through a download.
Is there a possibility it has something to do with the timer interrupts in the code or something like that?
Dashboard works fine through the usb to serial adapter.
But I am still having problems with programing it.
Last time it stopped working was in the middle of a transfer. This has happened before and i solved the problem by leaving it unpowered for 10 mins or so then re-connecting it. It by default goes into program state and i send it code.
Not working this time around. It fails to connect every single time.
Its doing this from a PC with a serial port too.
I have tried holding the program button down while powering it on, (which turn on only the power led and the program led) and i still have the same problem.
Next time that it decides to cooperate with you, I would recommend re-downloading the Master Code, and then downloading the default code again. I’m curious if it might be a firmware issue.
is there any way to reload the firmware without using IFI loader, as it will NOT connect to the RC anymore at all.
and yes i am sure that no other program is using the port.
and i have checked in device manager to make sure i am using the correct port. I have even tried changing the port, rebooting and it still doesn’t work.
I have not yet contacted FIRST, but I have contacted IFI, no response yet.
I am suspecting that it has something to do with the code we are uploading to the RC. as everything was working fine until we started messing with interupts and kevin’s ADC code.
hopefully IFI get’s back to me soon, and if I don’t hear from them by monday, i will contact FIRST as well as call IFI.
