Broken Links
I am still finding broken links just about everywhere. I kept trying to bring up JVN’s calculator but every link says “not found.” I know the update for a new site like this takes a long time. Do we have an update when this might be fixed?
Which links are you clicking, can you provide some examples?
I’ve got a few CD Media images and papers to fix – plan on doing that tonight, since I didn’t get a chance yesterday:
from what I can see anything in this format is broken.
http://www.chiefdelphi.com/media/papers/2755
Ah, it works if you open in a new browser window/tab. There’s a feature/bug in Discourse that prevents internal use of the redirects I used to preserve old links.
Bumping this, threads with “langid=” and “highlight=” break when coming both externally and internally.
https://www.chiefdelphi.com/forums/showthread.php?threadid=165202&langid=1
https://www.chiefdelphi.com/forums/showthread.php?t=160787&highlight=apple+pi+swerve
@Brandon_Martus FYI I found another broken link when reading an old thread. This link:
https://www.chiefdelphi.com/forums/showthread.php?p=1647943#post1647943
from this comment
is broken. The correct link is to this thread.
Bringing this back to life, someone else found a broken link.
http://www.chiefdelphi.com/media/papers/download/3028
Anotha one: https://www.chiefdelphi.com/forums/showthread.php?t=38737&page=2
It should lead to here: Drive-train shaft size
The &page=2 is what kills it.
I’ve updated the pattern to match that …
That link is now https://www.chiefdelphi.com/uploads/default/original/3X/e/f/ef10db45f7d65f6d4da874cd26db294c7ad469bb.pdf
I’ve updated a few, and am searching around for a few others.
(Please send me links to the posts where you find bad links, not the actual link, so I can fix the source.)
In Team Update 11, looks like the link https://www.chiefdelphi.com/forums/showpost.php?p=1667314&postcount=152 should point to Do LRIs wield too much absolute authority?.
It does if you open in a new browser tab/window, but I’ve fixed it either way.
Are all links supposed to be fixed by now? Searching through old threads I often come across broken links. Would you like every broken link reported? It seems like a lot are links to old papers that I have to access via the Wayback Machine.
Example:
http://www.chiefdelphi.com/media/papers/1443
From here:
@Brandon_Martus
Yeah, I can fix them relatively easily … post them here if you find any.
(This one you reported is fixed)
Can we also flag any posts with broken links?
Either works …
I think it is meant to link to Team #4335 signing off or Shadetree Robotics signs off
It goes to the 4335 thread.
It went to the right link … it needed to be opened in a new tab/window. (see: Old Threads with links to other threads broken)
Found one a couple days ago:
Does branding effect who you pick? - #12 by Skyehawk links to https://www.chiefdelphi.com/media/papers/1702 which is broken.
