Brown Out Error -Configuring Spark Max / Run Neo Brushless Motor thru PC
Brown Out error Spark Max appears to have been configured correctly
Hit run command , move slider - no motor motion
Have a 30 amp ATC breaker in the system and using my power generator board input is 12.6v Check all connections
any suggestions Can only load one file Will upload board layout if interested
![20241125_160642|690x388]
Hmm, looking at the screenshot, since your input voltage is reading 12.6V, it could still be a power delivery issue. Double-check that all your connections are solid especially on the power side and make sure the generator board is outputting steady voltage under load.
Also, how’s your motor wiring? If there’s a loose connection there, the motor might not move even if everything else looks good. Might be worth trying a different motor or bypassing the generator board temporarily to see if the problem continues.
What is that? Do you know how much current it can supply? A picture would help, but if it can’t supply a lot of current, this is the behavior I’d expect. If you can, try using a regular FRC battery.
Issue resolved - thanks - redid connects also used a Battery with 4 AMP Max cap
Issue Resolve - used Battery with 4 AMP Max cap ; redid connectors -Thanks
