Build Code Error
Any help would be appreciated in figuring out what’s causing the error and how to fix it. We imported our code from eclipse into visual studio and we are not sure what went wrong.
> Executing task: gradlew build  -Dorg.gradle.java.home="undefined" <
Downloading https://services.gradle.org/distributions/gradle-5.0-bin.zip
Exception in thread "main" java.net.UnknownHostException: services.gradle.org
        at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:184)
        at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
        at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
        at java.net.Socket.connect(Socket.java:589)
        at sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:666)
        at sun.security.ssl.BaseSSLSocketImpl.connect(BaseSSLSocketImpl.java:173)
        at sun.net.NetworkClient.doConnect(NetworkClient.java:180)
        at sun.net.www.http.HttpClient.openServer(HttpClient.java:463)
        at sun.net.www.http.HttpClient.openServer(HttpClient.java:558)
        at sun.net.www.protocol.https.HttpsClient.<init>(HttpsClient.java:264)
        at sun.net.www.protocol.https.HttpsClient.New(HttpsClient.java:367)
        at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(AbstractDelegateHttpsURLConnection.java:191)
        at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1156)
        at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1050)
        at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:177)
        at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1564)
        at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1492)
        at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:263)
        at org.gradle.wrapper.Download.downloadInternal(Download.java:66)
        at org.gradle.wrapper.Download.download(Download.java:51)
        at org.gradle.wrapper.Install$1.call(Install.java:62)
        at org.gradle.wrapper.Install$1.call(Install.java:48)
        at org.gradle.wrapper.ExclusiveFileAccessManager.access(ExclusiveFileAccessManager.java:69)
        at org.gradle.wrapper.Install.createDist(Install.java:48)
        at org.gradle.wrapper.WrapperExecutor.execute(WrapperExecutor.java:107)
        at org.gradle.wrapper.GradleWrapperMain.main(GradleWrapperMain.java:61)
The terminal process terminated with exit code: 1
Did you use the offline installer (recommended)? If not, you need to be connected to the internet the first time you build. The error is it’s trying to download gradle.
