I have this error, which I can’t figure out how to fix. I have the latest FRC Plugins and just imaged the Rio with 2017 v8. Here is the full output:
Buildfile: C:\Users\MHS\Documents\GitHub\FRC5113_2017\build.xml
Trying to override old definition of task classloader
clean:
[delete] Deleting directory C:\Users\MHS\Documents\GitHub\FRC5113_2017\build
[delete] Deleting directory C:\Users\MHS\Documents\GitHub\FRC5113_2017\dist
compile:
[mkdir] Created dir: C:\Users\MHS\Documents\GitHub\FRC5113_2017\build
[echo] [athena-compile] Compiling src with classpath=C:\Users\MHS\wpilib\java\current\lib\WPILib.jar;C:\Users\MHS\wpilib\java\current\lib\NetworkTables.jar;C:\Users\MHS\wpilib\java\current\lib\opencv.jar;C:\Users\MHS\wpilib\java\current\lib\cscore.jar to build
[javac] Compiling 10 source files to C:\Users\MHS\Documents\GitHub\FRC5113_2017\build
jar:
[echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
[mkdir] Created dir: C:\Users\MHS\Documents\GitHub\FRC5113_2017\dist
[mkdir] Created dir: C:\Users\MHS\Documents\GitHub\FRC5113_2017\build\jars
[echo] [athena-jar] Copying jars to build/jars.
[copy] Copying 4 files to C:\Users\MHS\Documents\GitHub\FRC5113_2017\build\jars
[jar] Building jar: C:\Users\MHS\Documents\GitHub\FRC5113_2017\dist\FRCUserProgram.jar
get-target-ip:
[echo] Trying Target: roboRIO-5113-FRC.local
[echo] roboRIO found via mDNS
dependencies:
[echo] roboRIO image version validated
[echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s/4485/m/13503/l/288822-installing-java-8-on-the-roborio-using-the-frc-roborio-java-installer-java-only
[sshexec] Connecting to roboRIO-5113-FRC.local:22
[sshexec] cmd : test -d /usr/local/frc/JRE
BUILD FAILED
C:\Users\MHS\wpilib\java\current\ant\build.xml:293: Remote command failed with exit status 1
Total time: 8 seconds
Here is our code - https://github.com/FRC5113/FRC2016_5113_2/commit/52c4894f9cd6021586963c9f21bce97d1b0d358d
I was not getting this error before I updated the plugins and reimaged the Rio. I have tried this on two different Rios, both on the same version - 2017 v8.
