Building Block 220 16:1 Gearbox CAD?
Hello there is not found anywhere, have you drawn or used it before?
Looking at the specs on BaneBots’ website it looks like you should be able to make a fairly accurate model of the gearbox yourself, the only major missing features being the mounting holes. If you really need an accurate CAD model now you could switch to using an Andymark Sport gearbox. They have CAD models and they’re a bit cheaper than the BaneBots ones. They are available in a 16:1 configuration.
thank you :slight_smile:
No problem. Good luck!
