Building error
Hi everyone,
We’re having the following error when we try to build the following code to the cRio:
http://imageshack.us/photo/my-images/714/compileerroru.png/
We have the lastest netbeans, and we imaged the cRio,
Can anyone help?
Thanks,2231
We just solved this error, we ended up disabling the firewall on the classmate.
It’s in the control panel under Security.
Thank you for your answer.
Do you know which static ip we should put for compile the java files to the controller?
Thanks, team 2231.
If you are running the Driver Station and dashboard on your development computer, use 10.x.y.6 for your IP address. If the driver station is also on the network, use some IP address not taken by the other parts of the system, like 10.x.y.42.
Brad
