I’m trying to get a usable build (and deploy) setup using just Gradle with Java, without installing VSCode (on MacOS 10.14.2).
Looking at the instructions https://github.com/wpilibsuite/GradleRIO/blob/master/README.md it says to download java.zip, which I did, and I extracted the .zip file. The instructions say that I just need to run “./gradlew build”
But when I do, I get:
FAILURE: Build failed with an exception.
- Where:
Build file ‘/Users/david/frc2019/GradleRIOjava/build.gradle’ line: 3
- What went wrong:
Plugin [id: ‘edu.wpi.first.GradleRIO’, version: ‘4242.1.1-ci’] was not found in any of the following sources:
… and so on.
Any clues on what my problem is?
David
