Building Outside of Frame (Kinda)
I remember seeing once a 3D printed part that would be attached to swerve module(MK4I) that would allow you to place gussets on the outside of the frame perimeter that were <=.25"
Is this a thing? If so, where can I find it? And most importantly, is it legal? Because the gap would only technically be <=.25" I assume it still passes R410.
Thanks in advance!
Generally speaking, that particular gusset type would actually become the Frame Perimeter. (Itā€™s NOT a ā€œminor protrusionā€.)
That said, as long as it didnā€™t cause you to be over the max Frame Perimeter, and you still properly supported your bumpers on the revised Frame Perimeter per R410, thereā€™s nothing saying you canā€™t use something like that.
It seems pretty common to design swerve dust shields that stick out past the module and tube frame. If that gap is larger than 1/4ā€ or your bumpers are a bit loose, youā€™ll need shims to take up that space every 8 inches.
Thatā€™s great to hear! I threw in the ā€˜kindaā€™ because it does basically become the frame perimeter but it is built outside of the walls that would normally define the frame perimeter.
Do youā€“or anyone for that matterā€“know of publically available designs for this that are compatible with the MK4I?
I know 111 and I think 3005 released designs for MaxSwerve, but Iā€™m not familiar with the MK4i versions. Itā€™s a pretty quick CAD project to design your own though I think it took me about 30 min to model a basic version.
We can definitely do it, just didnā€™t want to reinvent something that may already be available. Thanks for the help.
ā€œbasicallyā€, nothing. Thatā€™s exactly what it does. Itā€™s not a minor protrusion.
Iā€™m going to remind readers that in FRC, ā€œFrame Perimeterā€ has a very specific meaning, which informs a large number of other rules both in design/build and in gameplay. If youā€™re thinking of the Frame Perimeter as ā€œtubes around the outside of the frameā€ but then you put gussets on there, you just changed the definition of your Frame Perimeter, and should plan accordingly.
My apologies for being perhaps overly pedantic. I just have a long memory of issues with these things, mostly caused by people not fully understanding the Frame Perimeter and where it actually is. Iā€™m not sure how many teams Iā€™ve had rework their bumpers because of this type of understanding issueā€¦ I want you guys to get it right the first time so you can show up at inspection and get the very fast ā€œitā€™s good!ā€ not the ā€œyou need to rebuild all your bumpersā€.
(Back in when this was first introduced, just for bumper build at that time, bolt heads were included. That lastedā€¦ weeks maybe? Some of the other old-timers can correct me on that, we just kept asking about these things and how to measure 'em.)
