Hi everyone I am getting this when deploy my code what should I do? :
WARNING: Host is not on same subnet as robot. May not be able to complete all communication with robot.
Connecting FTP @10.0.0.2
C:\Users\FRC Team\sunspotfrcsdk\build.xml:79: The following error occurred while executing this line:
C:\Users\FRC Team\sunspotfrcsdk\ant\configure.xml:41:
java.net.ConnectException: Connection timed out: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:79)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at org.apache.commons.net.SocketClient.connect(SocketClient.java:182)
at org.apache.commons.net.SocketClient.connect(SocketClient.java:203)
at org.apache.commons.net.SocketClient.connect(SocketClient.java:296)
at com.sun.spot.sdk.tool.ftp.JakartaFtpWrapper.connectAndLogin(Unknown Source)
at com.sun.spot.sdk.tool.ftp.UpgradeTask.execute(Unknown Source)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:293)
at sun.reflect.GeneratedMethodAccessor42.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.taskdefs.Sequential.execute(Sequential.java:68)
at net.sf.antcontrib.logic.Switch$Case.execute(Switch.java:171)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at net.sf.antcontrib.logic.Switch.execute(Switch.java:138)
at org.apache.tools.ant.taskdefs.MacroInstance.execute(MacroInstance.java:396)
at org.apache.tools.ant.Target.execute(Target.java:435)
at org.apache.tools.ant.Target.performTasks(Target.java:456)
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1405)
at org.apache.tools.ant.Project.executeTarget(Project.java:1376)
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
at org.apache.tools.ant.Project.executeTargets(Project.java:1260)
at org.apache.tools.ant.module.bridge.impl.BridgeImpl.run(BridgeImpl.java:286)
at org.apache.tools.ant.module.run.TargetExecutor.run(TargetExecutor.java:555)
at org.netbeans.core.execution.RunClassThread.run(RunClassThread.java:153)
BUILD FAILED (total time: 28 seconds)
