One of the main factors that keeps us coming back to Birch plywood is that it is far less prone to warping after being cut either along or against the grain. Standard pine plywood, when cut in the 5-ish-or-so widths, just gets weird in unpredictable ways, regardless of grade.
Note that you will generally NOT see “Baltic” Birch plywood, as the Baltic moniker is typically reserved for hardwood boards and project panels that are MUCH more expensive than birch plywood.
Now, let’s talk about plywood grading. For bumpers in general, I recommend purchasing the hardest wood you can afford in the highest grade you can find, which will minimize imperfections and knots, and reduce the chances of warping. NOTE that plywood grading is a superficial grading, and inner construction is dependent on the core (see below).
Plywood grades are (best to worst) A, B, C and D for face or front face. The back grades are (best to worst) 1, 2, 3, and 4. Plywood grading standards are published by the Hardwood Plywood & Veneer Association.
Plywood grades of A1, A2, B1, B2 are a good two-sided product and would be used where both sides are going to be seen. The back side (number grade) does have a few more blemishes than the front.
A3, B3, C3 are for plywood that will be seen from one side, but the back side must be clean, although there may be some stain or discoloration on the back, spliced veneer, and so on. One might use this material for the sides of a dresser (who looks inside?), for drawer sides, and shelving.
A4, B4, C4 are a one-side-good product. The back may have open knots, filled knots, bad veneer joints or seams. This material will would work well for drawer bottoms, and similar.
Now, onto CORE grades!
From Professor Gene Wengert, Sawing and Drying Forum technical advisor:
Here is a description of the core choices that are available:
Core Types: Decorative hardwood plywood cores are mostly veneer (66 percent of the panels sold in North America), but may also be MDF (16 percent), particleboard (13 percent), or agrifiber and other materials.
Veneer core is made from multiple plies of veneer peeled from quality logs with limited aesthetic characteristics, and glued together with the grain direction alternating at right angles. Compared to MDF (medium density fiberboard) and particleboard, its advantages include higher strength, lighter weight (typically 70 pounds at ¾-inch thick), and excellent screw-holding properties. Disadvantages include potential variation in panel thickness; core textures may telegraph through the surface layer; and the edges must be covered.
MDF core are wood chips steamed and refined to fiber bundles, bonded, formed into a mat, pressed and then sanded to a desired thickness. Advantages include a smooth surface, uniform thickness, and reasonable screw-holding ability. Disadvantages would be that it’s heavy (100 pounds at ¾-inch thick), not as strong as veneer core, and the perception that it is not real wood.
Particleboard Particleboard cores are made from wood chips ground into small particles, bonded, mat formed, pressed and sanded to a desired thickness. Advantages include a smooth, uniform thickness and reasonable screw-holding ability. Cons would be that it’s heavy (100 pounds for ¾-inch panel), not as strong as veneer core or MDF, and again, the perception that it is not real wood
Combination core plywood consists of two types of construction. The first has a center veneer layered with a crossband veneer on both sides and then followed by a layer of MDF, particleboard or hardboard, plus the face and back veneers. The second type of construction has a wafer-board center with a veneer crossband on both sides, plus the face and back veneers. Combination core offers consistent flatness and good screw-hold ability in a lighter weight than MDF or particleboard.
Lumber core plywood is constructed from strips of solid lumber. Veneer is attached once the core has been surfaced. Lumber core plywood has good bounce-back, which makes it a good choice for constructing long or wide shelves in cabinets and closets. A more expensive plywood, it is diminishing in popularity.
It’s really no wonder why a lot of engineers hate wood as a medium, and I’m still kind of surprised FIRST still uses it as a fundamental construction material.
