I’ve been having trouble trying to find out how to assign motors to buttons. In vex you could do something like…
if(vexRT[Bn5U] == 1){
motor[left] ==127;
motor[right]==127;
else{
motor[left]==0;
motor[right]==0;
}’(everything probably not exact but its something like this)
so my teammate and I were trying to do the same in java for the frc programming but when we tried it, it did not work out well. We’ve been trying to fix it but were having trouble assigning motors(Victor, Talon, etc.) to buttons on our joystick(all motors, servos, encoders, and counters are initialized) . So if someone can help us out I will really appreciate it because it’s starting to bug me since I couldn’t figure it out. ^W^
This is our code now…
package org.usfirst.frc.team5432.robot;
import edu.wpi.first.wpilibj.CounterBase.EncodingType;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Servo;
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.TalonSRX;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.VictorSP;
import edu.wpi.first.wpilibj.buttons.JoystickButton;
The VM is configured to automatically run this class, and to call the
functions corresponding to each mode, as described in the IterativeRobot
documentation. If you change the name of this class or the package after
creating this project, you must also update the manifest file in the resource
directory.
RobotDrive myRobot;
Joystick stick;
Joystick xbox;
JoystickButton A;
JoystickButton B;
JoystickButton X;
JoystickButton Y;
JoystickButton LB;
JoystickButton RB;
JoystickButton BACK;
JoystickButton START;int counter1 = 0;
int counter2 = 0;
int counter3 = 0;
JoystickButton button1;
JoystickButton button2;
JoystickButton button3;
JoystickButton button4;
JoystickButton button5;
JoystickButton button6;
JoystickButton button7;
JoystickButton button8;
JoystickButton button9;
JoystickButton button10;
JoystickButton button11;
JoystickButton button12;
VictorSP rightMotors;
VictorSP leftMotors;
Servo retaining;
Servo shooting;
TalonSRX arm;
Victor shooter;
Talon lift;
Talon winch;
Encoder right;
Encoder left;
Encoder shootarm;public void roboInit() {
myRobot = new RobotDrive(0,1);
xbox = new Joystick(1);
A = new JoystickButton(xbox,1);
B = new JoystickButton(xbox,2);
X = new JoystickButton(xbox,3);
Y = new JoystickButton(xbox,4);
LB = new JoystickButton(xbox,5);
RB = new JoystickButton(xbox,6);stick = new Joystick(0); button1 = new JoystickButton(stick,1); button2 = new JoystickButton(stick,2); button3 = new JoystickButton(stick,3); button4 = new JoystickButton(stick,4); button5 = new JoystickButton(stick,5); button6 = new JoystickButton(stick,6); button7 = new JoystickButton(stick,7); button8 = new JoystickButton(stick,8); button9 = new JoystickButton(stick,9); button10 = new JoystickButton(stick,10); button11 = new JoystickButton(stick,11); button12 = new JoystickButton(stick,12); retaining = new Servo(9); shooting = new Servo(8); lift = new Talon(4); winch = new Talon(3); shooter = new Victor(5); leftMotors = new VictorSP(6); left = new Encoder(6,counter1,true, EncodingType.k1X); rightMotors = new VictorSP(7); right = new Encoder(7,counter2,true, EncodingType.k1X); arm = new TalonSRX(2); shootarm = new Encoder(2,counter3,true, EncodingType.k1X);
- This function is called periodically during autonomous
- This function is called periodically during operator control
myRobot.arcadeDrive(stick);
- This function is called periodically during test mode
public void testPeriodic() {
