Hello, I am currently the Programming Team Captain for my Robotics Team and we decided to switch to a command based program this year. We are inexperienced with joystick button bindings and are having difficulties with it. I was wondering if I could potentially get some help with this issue. Thank you.
Here is our current RobotContainer.cpp file with our button bindings:
/* Copyright © 2019 FIRST. All Rights Reserved. */
/* Open Source Software - may be modified and shared by FRC teams. The code */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project. */
#include “RobotContainer.h”
RobotContainer::RobotContainer() {
// Initialize all of your commands and subsystems here
m_joystick = new frc::Joystick(JOYSTICK_PORT);
frc::SmartDashboard::PutData(&m_drivetrain);
m_drivetrain.SetDefaultCommand(ArcadeDriveCommand(
&m_drivetrain,
[this] {return m_joystick->GetY(); },
[this] {return m_joystick->GetX(); }));
//frc::SmartDashboard::PutString(“DB/String 1”, “b4 read”);
m_wheel.SetDefaultCommand(GetColorCommand(&m_wheel));
m_camera.SetDefaultCommand(VisionCommand(&m_camera));
// Configure the button bindings
ConfigureButtonBindings();
void RobotContainer::ConfigureButtonBindings() {
// Configure your button bindings here
rotate_wheel = new frc2::JoystickButton(m_joystick, ROTATE_WHEEL_BUTTON);
rotate_wheel -> WhenPressed(RotateWheelCommand(&m_wheel));
set_color = new frc2::JoystickButton(m_joystick, SET_COLOR_BUTTON);
set_color -> WhenPressed(SetColorCommand(&m_wheel));
frc2::Command* RobotContainer::GetAutonomousCommand() {
// An example command will be run in autonomous
return nullptr;
