Button mapping in robotContainer.java gone wrong (REAL)
Heya there! So, i’ve been finishing up some button mapping before we test our robot. However, upon assigning a button to a certain function it proceeds to be non functional to summarize it.
m_operatorController
.a() //this is the part that is not functioning
.whileTrue(
m_shootingOrIntaking.intaking()
The method a(EventLoop) in the type XboxController is not applicable for the arguments ()Java(67108979)
You need to make m_operatorController a CommandXboxController object instead of just an XboxController object
Sure! Let me try that. Thanks.
Yea it works, now I have a new issue.
.a()
//this one is not functioning .whileTrue(
The method whileTrue(Command) in the type Trigger is not applicable for the arguments (void)Java(67108979)
m_shootingOrIntaking.intaking() needs to be a command factory method that has a return type of Command.
Thank you so much! It works as intended now. Have a great day.
