I have a relay programed to a button but now I want it to be a press to be forward and then press again to reverse. For example, I am using a selanoid and i want to press the button to have the cylinder go out then the next time i press it the cylinder go in. I can do this easilly in p-basic but I have tried to do it in C and I can’t get it to work right. Could anyone give me a hand with this by posting code. It would be appreciated. Thanks
Put something this in your user_routine, substituting appropriately for switch_value and relay_fwd/rev:
static char relay_state = 0; /* 0 means forward, 1 means reverse */
static char last_switch_value = 1; /* will remember the last state of the switch */
if ((last_switch_value == 0) && (switch_value == 1))
// here is where you toggle the relay state
relay_state = 1-relay_state;
if (relay_state == 0)
relay_fwd = 1;
relay_rev = 0;
else
relay_fwd = 0;
relay_rev = 1;
last_switch_value = switch_value;
Can’t you do:
//Init Relays
relay1_fwd = 1;
relay1_rev = 0;
if (OI_Switch)
relay1_fwd = !relay1_fwd;
relay1_rev = !relay1_rev;
Just be sure to only do it again after a certain time. 26.2 ms is still fast, 38 hz fast.
Clever. That would work. Just make sure to have the variables static.
We coded buttons/triggers to only activate on release, that helps control the longggggggggg button push
Phil
I would do this so your relays dont pulse 40x a second I don’t know whose code I just added to tho… sorry
int flag=0;
//Init Relays
relay1_fwd = 1;
relay1_rev = 0;
if (OI_Switch && !flag)
flag=1;
if (!OI_Switch)
flag=0;
Double clever!
[edit]
My code (With suggestion):
//Init Relays
relay1_fwd = 1;
relay1_rev = 0;
static char SwitchVals = 0;
if (OI_Switch)
SwitchVals = 1;
if (!OI_Switch & SwitchVals)
SwitchVals = 0;
Of course, you still have to integrate it.
