[C++] Use CAN Talons in RobotDrive
We are using CAN for the first time and after a few hours of learning how to do it, wiring, and formatting the Talons, our drive code didn’t work. I tried controlling each motor individually and it works perfectly, but we would like to use RobotDrive because we are using Mecanum wheels with a gyro. Here is the non-working code:
class Robot: public SampleRobot {
	Joystick driveStick;
	CANTalon leftFront;
	CANTalon leftBack;
	CANTalon rightFront;
	CANTalon rightBack;
	RobotDrive drive;
	Gyro gyro;
public:
	Robot() :
		driveStick(1),
		leftFront(1),
		leftBack(5),
		rightFront(2),
		rightBack(6),
		drive(leftFront, leftBack, rightFront, rightBack),
		gyro(0)
	void OperatorControl() {
		gyro.InitGyro();
		gyro.Reset();
		while (IsOperatorControl() && IsEnabled()) {
			drive.MecanumDrive_Cartesian(driveStick.GetX(),driveStick.GetY(),driveStick.GetThrottle(),gyro.GetAngle());
And here is the working code (I used tank drive to make it easier):
	CANTalon leftFront;
	CANTalon leftBack;
	CANTalon rightBack;
	Gyro gyro;
public:
	Robot() :
		driveStick(1),
		leftFront(1),
		leftBack(5),
		rightFront(2),
		rightBack(6),
		gyro(0)
		gyro.InitGyro();
		gyro.Reset();
			leftFront.Set(-driveStick.GetY());
			leftBack.Set(-driveStick.GetY());
			rightFront.Set(driveStick.GetThrottle());
			rightBack.Set(driveStick.GetThrottle());
Does anyone know why this doesn’t work? Thanks!
Have you tried connecting the TalonSRXs via the PWM? That may alleviate your problem. Could also check if your TalonSRXs have the latest firmware.
Check here: http://crosstheroadelectronics.com/Talon%20SRX%20User's%20Guide.pdf
Maybe grab the self test from the Rio web based configuration? Maybe its not in percent throttle mode. I don’t have the implementation of robot drive in front of me but I think it just uses Set().
What sort of problems are you encountering when you try to run the mecanum drive code? Does it simply not do anything at all, does it move the motors around but not in the way you expect, or something else? If the motors are running but the robot is responding how you expect, you should double check that everything is plugged into the right ports, that all the motors are turning the right direction, etc.
I updated all the Talons to 1.4 (the newest I think) and we’re trying to use CAN instead of PWM. Using PWM would involve soldering the CAN wires which we don’t want to do just yet.
I actually did do this earlier, but I had no idea what is means. When in drive, they are set to “No Drive” but otherwise set to “Throttle.” This seems like it could be the problem if I knew more about it.
Motors are not doing anything at all, but works fine when not using RobotDrive.
try calling
robotDrive.SetSafetyEnabled(false);
before the while loop in OperatorControl.
Edit: actually, try calling that in the Robot() constructor. It’s possible that the Talons are getting disabled before you start running the robot but that they aren’t getting properly re-enabled.
I actually tried that earlier when I had some motor controllers set up wrong, but I forgot to try it again! I’ll check back tomorrow and report if it worked or not.
If you are seeing kNoDrive then most likely set is not being called. See software reference manual for more details.
Can I just call Set() once at the beginning of teleop or is there something I have to change in RobotDrive? Unfortunately, I can’t test until Monday.
Are you calling Wait(.01) in your code? That may cause the code to do nothing.
Could also try creating a new project. Sometimes projects get messed up. On the surface, it may not seem like it matters, but it could be worth a try.
I reccomend you switch from using the SampleRobot project to using IterativeRobot and try the code again.
This should work, but as I don’t have a bot with TalonSRXs, I can’t confirm this, but you could try it. I have used the IterativeRobot class.
class Robot: public IterativeRobot
private:
	LiveWindow *lw;
	CANTalon leftFront = new CANTalon(1);
	CANTalon leftBack = new CANTalon(5);
	CANTalon rightFront = new CANTalon(2);
	CANTalon rightBack = new CANTalon(6);
	RobotDrive drive = new RobotDrive(leftFront, leftBack, rightFront, rightBack);
	Joystick stick = new Joystick(1);
	Gyro gyro = new gyro(0);
	void RobotInit()
		lw = LiveWindow::GetInstance();
	void AutonomousInit()
	void AutonomousPeriodic()
	void TeleopInit()
	void TeleopPeriodic()
		drive.MecanumDrive_Cartesian(stick.getX(), stick.getY(), stick.getThrottle(), gyro.getAngle());
	void TestPeriodic()
		lw->Run();
How would this be different than the code I started with? Iterative basically just adds a function to be called at the beginning, but doesn’t really change what is actually going on in the program.
Iterative waits for each driver station packet for each iteration, whereas your original code runs in a tight loop without waiting for input. If you added a 20ms sleep in your loop, it would be vaguely equivalent to the iterative version.
Either way, you should add some sleep to your loop, otherwise you’ll starve the rest of the threads on your system and you’ll encounter problems. I’d recommend using iterative robot instead though, then you don’t have to worry about things like that.
Thanks, I didn’t realize there was an actual difference in the how the program ran for iterative, so we will probably switch over to it today.
Please post your progress… we have the same exact need, and are hard coding our drive code currently… CAN has so many benefits, but so does using RobotDrive…
Thanks!
We haven’t had any time to test really, so we have just hardcoded the Mecanum drive with no gyro. I hope that we can get RobotDrive sorted out later today, but I’m not too sure. Of course I’ll post the solution here though if we find it!
This might help, I ran this code on my mec bot, with gyro and CANTalons. I use IterativeRobot (it’s just my preference).
Thanks! I’ll have to try this later. I did just get RobotDrive working by putting this before the drive function:
leftFront->SetControlMode(CANSpeedController::kPercentVbus);
leftBack->SetControlMode(CANSpeedController::kPercentVbus);
rightFront->SetControlMode(CANSpeedController::kPercentVbus);
rightBack->SetControlMode(CANSpeedController::kPercentVbus);
There are problems with this solution though. For example, I can’t reverse the motors anymore (it doesn’t drive as soon as I add SetInvertedMotor in). I have another idea though that I will try later.
Ok I got it working! It’s kind of an unusual workaround, but it works fine for us. Basically, create 4 fake motor controllers on unused PWM ports, and pass those to RobotDrive. From there, set the values of the real motor controllers to the values of the fake ones. Here is part of the code we used:
CANTalon *leftFront = new CANTalon(1); //Real ones
CANTalon *leftBack = new CANTalon(5);
CANTalon *rightFront = new CANTalon(2);
CANTalon *rightBack = new CANTalon(6);
TalonSRX *PWMlf = new TalonSRX(0); //Fake ones
TalonSRX *PWMlb = new TalonSRX(1);
TalonSRX *PWMrf = new TalonSRX(2);
TalonSRX *PWMrb = new TalonSRX(3);
	drive->MecanumDrive_Cartesian(driveStick->GetX(), driveStick->GetY(), driveStick->GetZ(), gyro->GetAngle());
	leftFront->Set(PWMlf->Get());
	leftBack->Set(PWMlb->Get());
	rightFront->Set(PWMrf->Get());
	rightBack->Set(PWMrb->Get());
