Does anyone have a CAD model of this years Camera or the mounting Hardware. This would be tremendously appreciated.
Thanks in Advance,
-RC
Thanks in Advance,
-RC
I have attached a zip with the camera and the mount there is a iges, stp, ipt
Camera_and_Mount.zip (1.39 MB)
YOU ROCK MAN YOU ROCK.
Also note that the Autodesk FIRST Base site has cad files for the KoP, including the camera and Pan-Tilt gimbal (requires log-in).
–Ryan
I don’t have an account to FIRST BASE but does anyone also have a CAD model of the servo aka vex servo.
thanks,
-rc
CAD models for all the Vex components are available on the Vex site.
CAD models for the Hitec servos (“regular” servos, solid black with white horns) can be found on FIRST Cad Library (INV)
I believe accounts on FIRST Base are free, if want access to full models of the KoP. Also, PTC has modeled the KoP in Pro/E.
Be careful with the Autodesk version of the camera. It does not include some of the bitmaps representing graphics on the camera and will cause resolution errors when brought in. You can resolve this by opening the part files causing the errors find the sketches that contain them and delete the referenced images. The same is true for the Jaguar PWM.
Good luck!
