So a disclaimer, I’m not an engineer by any means… which is why I’m asking
Trying to figure out what kind of material to use for a structural piece. For example, if I was planning on 1,000 lbs of weight as tension on aluminum square tube. From what I’ve seen, 6060 aluminum has a tensile strength of about 32,000 psi. I get force/area will give you psi, but how do you calculate the area for the tube? For a square tube, do you just use the area of the material? So the area of the diameter, subtracted from the area of the inner diameter? Or is it more complicated than that? And when it comes to tensile strength, does round/square tubing make a difference? Square is going to give more material in a given width, but how much does the shape come in to play?
Thanks!
